Best Practice for Applying Custom LineItem Pricing in Optimizely Commerce?
Hi everyone,
We’re implementing Floor Sample pricing (Custom Pricing) in an Optimizely Commerce 14 project and I wanted to check if the approach we’re using is considered best practice, or if there’s a more Commerce-native way to handle dynamic pricing.
Right now, when an item qualifies as a Floor Sample, we override the price directly on the line item:
lineItem.PlacedPrice = floorSamplePrice; // custom price from database - decimal
_cartRepository.SaveCart(cart); // Save cart after updating placed price
This works, but I’m not sure if overriding PlacedPrice is the recommended pattern, especially when:
  • promotions need to run on top of the modified price
  • cart recalculation happens (totals, taxes, fees, etc.)
  • the user refreshes the cart or shipping methods
  • the price needs to persist through checkout → purchase order conversion
  • we later need to audit/track that the price used was a floor-sample price
My questions:
  1. Is directly setting PlacedPrice the correct way to inject custom/dynamic pricing?
    Or should we instead be extending a service like:
    • IPriceService
    • IPlacedPriceProcessor
    • or IShippingPromotionProcessor (if price affects eligibility)?
  2. Does changing PlacedPrice interfere with the pricing engine or further recalculations?
  3. Should we be storing the Floor Sample price in a custom line item property instead of overwriting PlacedPrice, and let a custom price processor pick it up?
Looking for guidance from anyone who has implemented custom/dynamic pricing outside the standard Price Cards. Any best practices or pitfalls would be really helpful!
#341103
Edited, Nov 26, 2025 10:46
Hi everyone,
I want to share a more robust, maintainable approach for applying custom prices (like Floor Sample pricing) in Optimizely Commerce.
Why directly setting PlacedPrice is fragile
Previous code:
It works - but I found few drawbacks:
  • If the cart is recalculated (promotions applied, taxes, shipping, quantities changed), the overridden price may be overwritten or ignored.
  • Promotion engine, discounts, price adjustments expect pricing to come from the catalog/price service, so customizing price this way can lead to unexpected results.
  • Future upgrades or changes to pricing logic might break your custom override.
Recommended Pattern: Use a Custom Price Processor
Instead of manually setting PlacedPrice, a better pattern is:
  • Store your custom price in a custom line-item property (e.g. FloorSamplePrice)
  • Implement a custom IPlacedPriceProcessor that inspects that property and, when present, applies it as the placed price.
  • Let the rest of the Commerce pricing pipelines (promotions, taxes, recalculation) work as normal — now they will operate with your custom price as the base.
Example Implementation:
[ServiceConfiguration(typeof(IPlacedPriceProcessor))]
public class FloorSamplePriceProcessor : DefaultPlacedPriceProcessor
    public override void ApplyPlacedPrice(
        IOrderGroup orderGroup,
        IOrderForm orderForm,
        ILineItem lineItem,
        IMarket market)
        // If our custom price is provided, use it
        if (lineItem.Properties["FloorSamplePrice"] is string custom &&
            decimal.TryParse(custom, out var floorPrice))
            lineItem.PlacedPrice = floorPrice;
        else
            // fallback to standard pricing logic
            base.ApplyPlacedPrice(orderGroup, orderForm, lineItem, market);
When adding to cart:
lineItem.Properties["FloorSamplePrice"] = floorSamplePrice.ToString();
With that:
  • Custom price becomes part of the standard pricing pipeline — so discounts, promotions, taxes, shipping, and all calculations respect it.
  • If a line item doesn’t need custom pricing, default behavior remains unchanged.
This pattern aligns with how Optimizely Commerce expects custom pricing to be handled (via custom pricing providers / price processors).
If anyone else has implemented a similar pattern (customer-specific pricing, ERP-driven price feeds, display-sample pricing, etc.), I’d love to hear your feedback or lessons learned.
#341122
Edited, Nov 27, 2025 10:33
