I am trying to install EPiServer.Personalization.MaxMindGeolocation, and it shows when I choose the optimizely package source.
Problem is that the installation fails, with 2 errors:
NU1301 Failed to retrieve information about 'EPiServer.Framework' from remote source 'https://www.david-tec.com/optimizely-nuget-feed-explorer/FindPackagesById()?id='EPiServer.Framework'&semVerLevel=2.0.0'. NU1301 Failed to retrieve information about 'EPiServer.Personalization.MaxMindGeolocation' from remote source 'https://www.david-tec.com/optimizely-nuget-feed-explorer/FindPackagesById()?id='EPiServer.Personalization.MaxMindGeolocation'&semVerLevel=2.0.0'.
I have tried to browse to the package source address https://api.nuget.optimizely.com/v3/index.json and it answers just fine, but it seems like that is just a kind of shortcut. I also tried the direct approach, using another package source, https://www.david-tec.com/optimizely-nuget-feed-explorer which also answers from the browser, but in visual studio it gives this additional error:
[Optimizely Nuget Explorer] The V2 feed at 'https://www.david-tec.com/optimizely-nuget-feed-explorer/Search()?$filter=IsLatestVersion&searchTerm='maxmind'&targetFramework='net8.0'&includePrerelease=false&$skip=0&$top=26&semVerLevel=2.0.0' returned an unexpected status code '500 Internal Server Error'.
Just to have mentioned, I am trying to get the latest stable, 2.3.0
Am I missing something obvious, or are there a problem somewhere ?
You should unselect the david-tec source. it is throwing error that stops VS from getting data from other sources. You should be able to use only these two
error This topic was created over six months ago and has been resolved. If you have a similar question, please create a new topic and refer to this one.
Jan Rasmussen
