Restrict which blocks that can be used in TinyMce.
Is there a way to restrict which types of block are allowed in TinyMce (like you can do with AllowedTypes-attribute on ContentArea property)?
We have a project which contains two sites and I want to specify which blocks are available on Site A and which blocks are available on Site B.
#322602
Edited, May 24, 2024 10:56
If you have a different role per site, you can use this to restrict who can see each block.
Blocks can have an Access attribute like so:
[ContentType(DisplayName = "Test Block", GUID = "xxxx-xxxx")]
[Access(Roles = "SiteBRole")]
public class TestBlock : BlockData {
This'll filter out the block for everyone not in the SiteBRole.
If you want to filter it per site, you can implement a ContentTypeAvailabilityService  as suggested here.
It'll allow you to filter the list of pages and blocks per your own criteria.
#322718
May 27, 2024 5:42
This can be done but you need to write a validator for the XhtmlString type (in combination with Arjan Paauw's answer).
Here's a brilliant blog post on it, https://surjitbharath.wordpress.com/2017/02/02/episerver-10-restrict-any-block-types-on-xhtmlstring-property-using-the-validation-attribute/
Codesnippet from Surjit's Dev Blog
Property
[Display(Name = "Text", GroupName = SystemTabNames.Content)]
[XHtmlStringAllowedBlockTypes(new[] { typeof(TextBlock), typeof(ImageBlock) })]
public virtual XhtmlString RichText { get; set; }
Attribute
public class XHtmlStringAllowedBlockTypes: ValidationAttribute {
  private readonly Type[] allowedTypes;
  public XHtmlStringAllowedBlockTypes(Type[] allowedTypes) {
    this.allowedTypes = allowedTypes;
  protected override ValidationResult IsValid(object value, ValidationContext context) {
    var contentData = context.ObjectInstance as IContentData;
    if (contentData != null && contentData.Property[context.MemberName].Value is XhtmlString) {
      var richTextProperty = (XhtmlString) contentData.Property[context.MemberName].Value;
      foreach(ContentFragment fragment in richTextProperty.Fragments.Where(x => x is ContentFragment)) {
        var content = ServiceLocator.Current.GetInstance < IContentRepository > ().Get < IContentData > (fragment.ContentLink);
        foreach(var allowedType in allowedTypes) {
          if (allowedType.IsInstanceOfType(content)) {
            return new ValidationResult(string.Format("You cannot add {0} to {1}", content.GetType(), context.MemberName));
    return ValidationResult.Success;
#322719
Edited, May 27, 2024 7:15
Thanks for the advice guys. I implemented a ContentTypeAvailabilityService  that did the trick for me :)
#322720
May 27, 2024 7:44
