Hi Kumar
You have already registered your service successfully. How do you know it is not calling? Did you inject ISettingService into anywhere in your code?
p.s. In your above example, you have registered the same SettingService twice with different lifecycles , this would cause a lot of confusion, and I suggest you choose only one.
It seems you created three threads of same topic. I deleted one but two have answer(s) so I will leave them be. the other thread is How to register service in the startup.cs file. | Optimizely Deve
Hi Team,
I have implemented one of the settings service as below
public class SettingsService : ISettingsService
and register the above service in startup.cs like below
public void ConfigureServices(IServiceCollection services)
services.AddSingleton<ISettingsService,SettingsService>();
services.AddTransient<ISettingsService,SettingsService>();
but it's not calling "SettingsService". could you please help us how can we call the "SettingsService" in Optimizely CMS 12 & .netcore 6.0
