Forms, error on submitting with DdsEncryptedPermanentStorage provider
Arjan Paauw
Arjan Paauw
DXP Administrator CertificationPaaS CMS Developer Certificationworkspace_premium
On enabling the DdsEncryptedPermanentStorage provider, I get the following error on submitting a form:
It is setup with:
I had errors for read access to the keyvault and my key size before, and after fixing those I'm left with the above error.
Am I missing something?
I'm using key 1234567812345678 as base64 MTIzNDU2NzgxMjM0NTY3OA==
#318536
Mar 06, 2024 2:27
Seems like your Submission.Id is not a Guid value. Do you have any custom code that manipulates that?
#318563
Mar 06, 2024 22:25
Arjan Paauw
No it is just standard Form Container. It also works fine when I swap back to the non-encrypted provider.
#318599
Mar 07, 2024 1:46
Ronil Rangaiya
Is session state enabled ?
Form data encryption requires session state. If disabled, it may be causing the provider to not correctly assign the Submission Id during the save operation.
#319239
Mar 20, 2024 6:39
