Sustainsys Saml2 & AspNetIdentity multiplex login
I am trying to configure our Optimizely CMS 12 to use multiplex login to the CMS.
I want to use both SAML2 using Sustainsys and AspNetIdentity authentication to access the CMS.
The configuration doesn't seem to do it, I can login with the CMS user but nothing is happening when I signin with SAML2.
I get redirected to the front page, without any access. The session cookie is set, but it seem that no access rights are given?
There is probably configuration missing, however I don't know what it is.
I've also tried the AddPolicy approach which didn't make any difference.
When I only choose to sign in with Saml2, it works. Same thing with AspNetIdentity. But they are not working when I try the multiplex appraoch.
This is the configuration:
public void ConfigureServices(IServiceCollection services)
    if (_webHostingEnvironment.IsDevelopment())
        //Add development configuration
    services.AddRedirectManager(
        addQuickNavigator: true,
        enableChangeEvent: true);
    services.AddMvc();
    services.AddCms().AddCmsAspNetIdentity<ApplicationUser>();
    services.ConfigureOptimizely(_configuration, _webHostingEnvironment);
    services.AddFind();
    services.ConfigureApplicationCookie(options =>
        options.LoginPath = "/util/Login";
    services.AddEmbeddedLocalization<Startup>();
    services.Configure<VisitorGroupOptions>(o => { o.EnableSession = true; });
    services.AddIdp(_configuration);
public static IServiceCollection AddIdp(this IServiceCollection services, IConfiguration configuration)
    var appSettings = configuration.GetSection(nameof(ApplicationSettings)).Get<ApplicationSettings>();
    services.AddAuthentication(options =>
        // Default scheme that maintains session is cookies.
        options.DefaultScheme = CookieAuthenticationDefaults.AuthenticationScheme;
        // If there's a challenge to sign in, use the Saml2 scheme.
        options.DefaultChallengeScheme = Saml2Defaults.Scheme;
        options.DefaultForbidScheme = CookieAuthenticationDefaults.AuthenticationScheme;
         .AddCookie(options =>
             options.Events.OnSignedIn = async ctx =>
                 if (ctx.Principal?.Identity is ClaimsIdentity claimsIdentity)
                     // Syncs user and roles so they are available to the CMS
                     var synchronizingUserService = ctx
                       .HttpContext
                       .RequestServices
                       .GetRequiredService<ISynchronizingUserService>();
                     await synchronizingUserService.SynchronizeAsync(claimsIdentity);
         .AddSaml2(options =>
             options.Notifications.AuthenticationRequestCreated = (ar, idp, props) =>
             options.Notifications.AcsCommandResultCreated = (c, r) =>
             //options.SignInScheme = CookieAuthenticationDefaults.AuthenticationScheme;
             options.SPOptions.EntityId = new EntityId(appSettings.IdpSettings.EntityId);
             options.SPOptions.ReturnUrl = new Uri(appSettings.IdpSettings.ReturnUrl);
             //options.SPOptions.PublicOrigin = new Uri(appSettings.IdpSettings.PublicOriginURL);
             options.SPOptions.ServiceCertificates.Add(new X509Certificate2(appSettings.IdpSettings.CertificateFile, appSettings.IdpSettings.CertificatePassword, X509KeyStorageFlags.MachineKeySet));
             var idp = new IdentityProvider(new EntityId(appSettings.IdpSettings.IdentityProvidersEntityId), options.SPOptions)
                 MetadataLocation = appSettings.IdpSettings.MetadataLocation,
                 //LoadMetadata = true,
                 //Binding = Sustainsys.Saml2.WebSso.Saml2BindingType.HttpRedirect,
                 //SingleSignOnServiceUrl = new Uri(appSettings.IdpSettings.SingleSignOnServiceUrl)
             options.IdentityProviders.Add(idp);
    return services;
#317401
Feb 20, 2024 11:49
I'm not that familiar with the SAML2 auth scheme. But pretty sure you need to give the sign-in cookie scheme a name and then specify that name in the SAML2 options sign-in scheme name.
#317407
Edited, Feb 20, 2024 15:46
I've tried a lot of different ways, but I now get a 500 error with the following message in the log:
The authentication handler registered for scheme 'Saml2' is 'Saml2Handler' which cannot be used for SignInAsync. The registered sign-in schemes are: Identity.Application, Identity.External, Identity.TwoFactorRememberMe, Identity.TwoFactorUserId, Cookies.
Not sure if it's correctly configured, but if it is, does it mean that Saml2 isn't supported in multiplex solution out of the box?
#317802
Feb 27, 2024 7:11
All schemes and setups are supported, it has nothing to do with the CMS. This is "just" asp.net core.
Can you get SAML2 to work on its own? I would start there.
#317803
Feb 27, 2024 7:25
I see, thank you for clarifying that.
Yes, SAML2 works on it's own, without using AspNetIdentity.
It's when "AddCmsAspNetIdentity" is used along with SAML2 when SAML2 stops working.
#318276
Edited, Feb 29, 2024 12:09
I solved it.
When using AspNetIdentity along with in my case SAML2 I needed to use IdentityConstants.ApplicationScheme as DefaultScheme instead of CookieAuthenticationDefaults.AuthenticationScheme.
Same goes for SignInScheme and SignOutScheme.
Thank you for your help Johan.
Update:
I created a blog post about this:
https://mikaelmansour.com/blog/how-to-enable-multiplex-login-in-your-optimizely-cms-12-website-using-sustainsys-saml2-idp/
#318406
Edited, Mar 03, 2024 12:31
