One way you can do this is to use projects and edit both the page and the block within the context of a project. If you don't use projects, the page will pull through the latest published version of the block so you won't be able to see your changes.
Hi, I have a query. If we add shared blocks to a page, but the block is not published yet. Can it be previewed? Currently I don't see it on previewing the page. It starts to show only once the block is published.
The CMS version we are using is -
Episerver.CMS - 12.31.2
Episerver.CMS.Core - 12.22.0
