Optimizely Graph .NET -- Try to add fragment
I am trying to create a query with fragment and hopefully to get the query like this.
query ArticleListing {
  ArticlePage {
    items {
      Name
      Url
      Title
      PreviewImage {
        Expanded {
          ...Image
    total
fragment Image on ImageFile {
  Name
  Url
  Title
  Width
  Height
I have a code below so far
            var fragmentImage = new FragmentBuilder<ImageFile>("Image").Fields(x => x.Name
        , x => x.Url
        , x => x.Title
        , x => x.Width
        , x => x.Height);
            articleQuery = articleQuery
                                .Fields(x => x.Name, x => x.Url, x => x.Title)
                                .Field(x => x.PreviewImage.Expanded).AddFragments(fragmentImage);
But it puts the "...Image" outside the PreviewImage.Expanded
  ArticlePage {
    items {
      Name
      Url
      Title
      PreviewImage {
        Expanded
      ...Image
    total
  Name
  Url
  Title
  Width
  Height
Is there a way to make fragment to be in the PreviewImage.Expanded ?
#331105
Oct 08, 2024 13:00
What is Optimizely CMS version and Graph Client .NET version that you are using?
#331163
Oct 09, 2024 8:25
hi Binh Nguyen Thi,
The Optimizely CMS is 12.29.1, and the Optimizely.Graph.Client version is 1.2.0
#331164
Oct 09, 2024 8:51
Hi Nattawut,
Optimizely.Graph.Client version is 1.2.0 doesn't support fragment in a specific field unfortunately. This should be a missing part and need to be updated. In the meanwhile please select fields directly in the query builder or build a small part of ArticlePage for reuseable.
  var fragmentForImage = new FragmentBuilder<ArticlePage>("PreviewImageFragment")
         .Fields(_=> _.PreviewImage.Expanded.Name, _ => _.PreviewImage.Expanded.Url, _ => _.PreviewImage.Expanded.Height);
          .AddFragments(fragmentForImage);
#332489
Nov 06, 2024 4:25
