The message can be set in your language files the same way as other translatable strings. The key is "/episerver/forms/viewmode/readonlymode" so you can either add the relevant XML to an existing language file or create a new one like this:
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<languages>
<language name="English" id="en">
<episerver>
<forms>
<viewmode>
<readonlymode>READONLY MODE! No forms for you.</readonlymode>
</viewmode>
</forms>
</episerver>
</language>
</languages>
Remember to set "embeded resource" in VS File Property... if you add the file for the first time. =)
On a form, I get this message when smooth deployment is underway:
Read-only mode. Submitted data is not saved.
Can this message be changed?
