Regular expression isnt working as expected on one of the fields in block
I am attempting to create a regular expression for one of the fields in my component block however it doesnt seem to be working. the field needs to accept forward slashes
  [Display(Name = "Theme",
            Description = "Choose from pre-defined Theme",
            GroupName = TabNames.CampaignSettings,
            Order = 10)]
        [AutoSuggestSelection(typeof(BrandThemeSelectionFactory))]
        [RegularExpression(@"^[a-zA-Z0-9\s/]*$")]
        [CultureSpecific]
        public virtual string Theme { get; set; }
Does anyone know what im doing wrong here?
#307687
Edited, Aug 30, 2023 16:24
How do you mean it "doesn't seem to be working"? It should only allow ContentReference so / is not allowed even if you have regex allow it
#307723
Aug 31, 2023 5:59
Hi quan, my apologies, i posted the wrong code! I've updated my post again and replaced it with the correct field. There is a drop down list in the campaign settings, and when i select one of the string theme names, and publish the  page, the drop down list appears empty instead of being populated.
#307730
Edited, Aug 31, 2023 9:43
Arjan Paauw
I'd use an enum property.. much cleaner. Only works if your Themes are really very predefined of course.
#307807
Sep 01, 2023 0:50
