ModelState is not valid
EVT
EVT
Did anyone else run into an issue after project upgrade that now Microsoft.AspNetCore.Mvc ModelState is validating not just controller's model?
We have an issue that a customer cannot end purchase journey because there a required field in home page that is not filled in.
#306230
Aug 04, 2023 9:24
Hi EVT
Is your project having nullable feature enabled? Can you check your csproj file? If your application is built with nullable enabled and by default mvc will validate all non-nullable properties or parameters. That's the fundamental change with nullable feature enabled from what I understand.
Unfortunately I don't have much information from what you described above, I hope my answer would help.
#306575
Aug 10, 2023 12:53
EVT
I have posted my question on StackOverflow. Unfortunately I cannot remove the inheritance so I have written a custom validation rather than using ModelState.IsValid.
#306624
Aug 11, 2023 8:30
I don't quit get it. Your issue does not seem related to inheritance. Do you have nullable enabled?
If the issue is caused by nullable reference type, you can disable this behavior using the following code
builder.Services.AddControllers(
    options => options.SuppressImplicitRequiredAttributeForNonNullableReferenceTypes = true);
#306629
Aug 11, 2023 9:30
EVT
I have a property in a class that is null BUT that entire class should not be validated.
It is a property in a Home page while the controller / view model / class is a Billing page.
And it did not work this way before the change (Microsoft.AspNetCore.Mvc.ModelBinding.ObjectModelValidator and System.Web.Mvc.ModelStateDictionary)
#306634
Aug 11, 2023 9:34
