Hi Mikael,
Yes you can hook into those events and then using the built in caching system you can clear / change the values have a look at this documentation for guidance.
https://docs.developers.optimizely.com/content-management-system/docs/object-caching
Paul
Thank you Paul for you quick answer.
Another question is what is the proper way to fix this issue? Is it to update the cache or should I use another service to resolve the URL?
Regards
Mikael
The cache should be updated whenever you update the page (move etc.) I think there was a bug before with cache invalidation. Let me check
I believe this might be related to bug CMS-26486 which was fixed on 12.13. however this should only occur in multi instances scenarios - i.e. if you edit in one instance and then check another instance, the cache might not be invalidated properly
I have some problem if I move a published page from one location to another, the URL will not directly update. So when a user comes in to the page it will link to the old location and say it not exists.
My thought is that is a URL cache that not been updated when i change the location.
I using the UrlResolver when create the links.
Have you some suggestion how I can fix this issues?
Is it possible to update the cache in a Content-event regarding OnMoveContentEvent?
I'm using Optimizely CMS 12 (v12.11.0)
Great Regards
Mikael
