Hide/Show block property based on some other property in same block
ZZ
ZZ
Is it possible to hide/show block properties based on someother block, Lets say I have string property in a block and I want to hide it in a block based on another boolean property in the same block. Is that possible in CMS 12. ?
#306558
Aug 10, 2023 9:10
Hi ZZ
Have you tried this? I hope this helps
https://gregwiechec.com/2018/03/hide-tabs-and-properties-in-edit-mode/
#306566
Aug 10, 2023 11:05
ZZ
I have tried but it doesn't work. I am trying to use this link to create custom attribute https://docs.developers.optimizely.com/content-management-system/docs/writing-custom-attributes
but having difficulty to get the value of the property in CreateDisplayMetadata ()
public class HideFieldAttribute : ValidationAttribute, IDisplayMetadataProvider
        private readonly string _fieldName;
        public HideFieldAttribute(string fieldName)
            _fieldName = fieldName;
        public void CreateDisplayMetadata(DisplayMetadataProviderContext context)
            // get value of the property ??
            throw new NotImplementedException();
#306570
Edited, Aug 10, 2023 11:44
Hi ZZ
I see you tried to roll out your own implementation with the dev doc, but your requirement is more complex and just implement a custom attribute would not be sufficient, because of this reason I suggested the package above.
P.S. The package I mentioned earlier does exact what you need. I used in other projects in the past, and worked like a charm.  In addition, it's open source, if you really keen to do your own implementation, check out the source to see what might be required.
#306571
Aug 10, 2023 12:24
ZZ
Whats the name of the NuGet package and is this compatible with CMS 12.17.x ?
#306574
Aug 10, 2023 12:49
Package is called Alloy.HideTabs --
It is compatible with CMS 12, yes.
#306580
Aug 10, 2023 18:56
ZZ - Aug 11, 2023 9:30
I tried but this doesn't work
Another approach to showing/hiding properties based on another property's value can be found here:
https://www.codeart.dk/blog/2022/11/property-dependency-in-optimizely-episerver-cms-12/
#306581
Aug 10, 2023 18:57
