It should sync content type changes automatically: https://docs.developers.optimizely.com/digital-experience-platform/v1.4.0-content-graph/docs/synchronizing-from-site
As a first step, I would review the setup instructions, and make sure it's fully configured (including the Content Delivery API setup): https://docs.developers.optimizely.com/digital-experience-platform/v1.4.0-content-graph/docs/installation-and-configuration
Thanks for the reply Daniel.
I've setup as per the documentation (I had missed off the "Include" section). However, it's still not syncing newly created fields.
If I add a property to an existing Content (block) type or create a completely new one, it won't appear in the graph until I do a full sync.
I am creating/updating the block content each time.
My config is as follows:
"Optimizely": {
"ContentGraph": {
"ContentVersionSyncMode": "PublishedOnly",
"SyncReferencingContents": "true",
"Include": {
"ContentIds": [],
"ContentTypes": []
"OnlySyncContentTypesInWhitelistToSchema": false,
"GatewayAddress": "https://cg.optimizely.com",
"AppKey": "b...W",
"Secret": "g..B",
"SingleKey": "H..M",
"AllowSendingLog": "true"
And code in Startup.cs:
services.ConfigureContentApiOptions(o =>
o.IncludeInternalContentRoots = true;
o.IncludeSiteHosts = true;
o.EnablePreviewFeatures = true;
o.SetValidateTemplateForContentUrl(true);
services.AddContentDeliveryApi();
services.AddContentGraph(_configuration);
I am experimenting using Graph QL.
I am adding new properties to a given block type, but I am finding that I have to run the "Content Graph content synchronization" job before the schema is updated on the Graph database.
I can update existing fields and that content is synced, but the new fields cannot be queried until I run the job.
is this expected behaviour, or is there something else I need to do to allow schema updates without the full resync?
