Not sure if this will help your issues, but order tends to matter with middleware. I've found for rewrite to work correctly it needed to be before status code rewrites if you use those and before Geta Not Found Handler. Here's what I've used in configure:
using (var stream = File.OpenText("RewriteRules.config")) {
var options = new RewriteOptions()
.AddIISUrlRewrite(stream);
app.UseRewriter(options);
app.UseStatusCodePagesWithReExecute("/error/{0}");
app.UseNotFoundHandler();
app.UseOptimizelyNotFoundHandler();
Hello,
We have custom redirect rules applied using rewriter options and calling it from Startup -> Configure() method using app.UseRewriter(RewriteOptionsHelper.rewriteOptions);
But this stops the buttons of add-on of Geta from working as it might be clashing with it.
We tried to use INotFoundHandler interface to provide custom rules but that's stops edit section of CMS 12 to load and gives scripts error in console.
Can you please guide and help us to resolve the issue.
Deepa
