Set user interface language for all users
Hi, how do you set global user interface language for the editor/admin interface? https://docs.developers.optimizely.com/content-management-system/docs/determining-languages The documentation is giving me nothing. Am I suppose to set something in Startup.cs or in appsettings.json?
#304932
Jul 10, 2023 16:28
Hi Tam,
Each user can set their own language through the CMS see here for details:
https://webhelp.optimizely.com/latest/en/content-cloud-for-editors/multiple-languages.htm
Otherwise it will fallback I believe to the default configuration.
You can customise this see https://docs.developers.optimizely.com/content-management-system/docs/localizing-the-user-interface.
Checkout how to configure the fallback culture also https://world.optimizely.com/documentation/developer-guides/archive/-net-core-preview/CMS/configuration/Configuring-cms/#localizationOptions
Paul
#304991
Edited, Jul 11, 2023 12:18
Tam Duc Ha Vo - Jul 12, 2023 3:42
Hi, Paul
Aha, so I can just specify «FallbackCulture»: «no» in appsettings.json?
Hi Tam,
That or
  services.Configure<LocalizationOptions>(o => o.FallbackCulture = new System.Globalization.CultureInfo("no"));
Should do the trick.
Paul
#305043
Jul 12, 2023 8:16
Hi Paul
Thank you for the quick reply. I have added the line of code in Startup.cs, but it seems like the language in the interface is still in english?
Maybe I'm missing something
#305045
Jul 12, 2023 8:38
Use this as part of your middleware in startup.cs.
var globalizationSettings= ServiceLocator.Current.GetInstance<GlobalizationSettingsOptions>();
globalizationSettings.UICultureLanguageCode= "no";
If the user has specifically set a language in their profile then it will prioritize that over the code above.
#305055
Jul 12, 2023 13:13
Hi Surjit,
Would this also work?
services.Configure<GlobalizationSettingsOptions>(o => o.UICultureLanguageCode = "no");
Paul
#305104
Edited, Jul 13, 2023 8:12
Tam Duc Ha Vo - Jul 13, 2023 11:33
That seemed to have done the trick. Thank you!
