Help me understand how inline editing is triggered
When editing a page using On-Page Editing mode and clicking on a string property you'd either get "inline editing" right there on the page, or a modal window appears with a form field for you to use. What exactly are the conditions for "inline editing" to work? Just using a standard MVC project with the property being rendered in a razor view using the @Html.PropertyFor() helper will yield "inline editing" for me (CMS 11). However using CMS 12 with a different approach (decoupled frontend, nextjs application) I cannot get the CMS to give me inline editing, it will only give me the "floating" modal variant. From what I've gathered the attribute
data-epi-edit
should be the equivalent of setting
data-epi-property-name="YourProperty" data-epi-property-render="none" data-epi-property-edittype="floating"
and I want to get edittype="inline" so I tried setting my elements to
data-epi-property-name="YourProperty" data-epi-property-edittype="inline"
but no matter what I try the result is still "floating".
Also why would data-epi-edit default to "floating", isn't "inline" editing the preferred UX for editors?
Any ideas on how I can achieve inline editing in my decoupled project?
#304702
Jul 05, 2023 13:40
