Change UI for insert/edit link
Hi, is it possible to modify the UI for insert/edit link modal? As of now we have it like this, but another platform has it like this
The picture on the left is what we have right now, but we want to have it like the picture on the right. It's more compact.
#304678
Jul 05, 2023 9:12
The picture on the left is CMS 12, and the picture on the right is CMS 11.
Of course you could register your own .css file, trying to override the default styles to make the new UI more compact, but I would not recommend that. It will be a headache once Optimizely updates their UI again, and it would probably not look too good unless you put a lot of effort into it.
If you make your browser window taller, you can avoid scrolling inside the CMS 12 dialog. The height adapts to your browser window height.
#304749
Edited, Jul 06, 2023 10:28
Tam Duc Ha Vo - Jul 06, 2023 11:39
Ah, okey, we thought it was CMS 12 as well. Then we wont have to do anything, thank you!
