Your question is somewhat unclear, can you please describe a bit more, possibly add some code etc
Some suggestions to investigate in your code, otherwise show us what you have and we can suggest a possible cause and fix (please remove client names, etc before posting).
Paul
I am facing one issue that
I have constructed a schedule job to update RTE fields with a page if it contains empty div tags, now the problem is i have a page with a IList of fields, on of which will be an RTE field, now this field is not getting saved.
