Hi, Is there a way in Optimizely to republish everything at the same time?
Our client that we are working with currently have some pages with broken links. We have attempted to run a report in the CMS  > Admin > Scheduled Jobs > Link Validation.
After our client ran this it didnt give them a report of what they wanted, they were expecting a list of pages that have links with a specific url syntax.
We have concluded that republishing everything would be the best approach to take, as it should fix all links. Otherwise it would result in the client checking each page manually, which isnt an efficient way of correcting the errors.
My question is, are there any packages or settings in this CMS which would allow us to republish everything? or would it be best to write a script in the BE that could handle this? If we did this we would need to avoid republishing anything that is in draft (has pending changes
Any help would be amazing!
Thankyou
#303880
Edited, Jun 21, 2023 9:58
Hi Aaron,
I think your best approach would be to write a script to do this.
You could use projects to add all the items you want to republish into it and then review those before republishing.
Paul
#303882
Jun 21, 2023 10:09
Thank you Paul!
#303886
Jun 21, 2023 10:36
Why do you have broken links?
If it is because things have changed locations, there will be issues when someone else has a link to the site, eg. search engines, someones bookmarks, etcetera. If this is the case you should handle this as well, with some kind of redirect handling.
#303888
Jun 21, 2023 11:42
Hi Svante,
Very true, the broken links could be from Google Search Console and to handle these you could use this widely populate package from Geta. This is an updated version also for CMS 12
Paul
#303890
Jun 21, 2023 14:30
