Enabling/Disabling scheduled jobs in 12.17.1
I just upgraded Episerver.CMS.UI to 12.17.1 and I see there's lots of changed to the Admin-UI for scheduled jobs and I don't see how you are supposed to enable or disable jobs anymore? I guess i can defacto disable a job by setting the next runtime to the year 2999. But I don't see any workaround for jobs that were disabled before the upgrade and that I want to enable. For disabled jobs the fields for next runtime are disabled. I can enable them manually and save next runtime, but the job remains disabled. I can also run the job manually, but this also doesn't enable the job.
So how am I supposed to enable a disabled scheduled job after upgrading to 12.17.1?
#301354
May 08, 2023 11:00
Hey Frank,
If I understood correctly, and if following helps you please let me know,
"If you select Manual, the Start Date field does not display and the job is considered inactive. Inactive jobs must be started manually. The other options are counted as active status and display the Start Date field."
Reference: https://support.optimizely.com/hc/en-us/articles/4413192306317-Scheduled-jobs
#301361
May 08, 2023 15:24
I believe a fix for this is coming in EPiServer.CMS.UI 12.20.0: https://world.optimizely.com/documentation/Release-Notes/ReleaseNote/?releaseNoteId=CMS-27187
#301362
May 08, 2023 16:04
