Configure TinyMCE on FormContainerBlock submission email
I would like to enable the source code editor in TinyMCE for just the message field of the FormContainerBlock submission email. I don't see a way to do this since you can only configure interfaces of IContentData. I think the data type I'm trying to configure is the Body field of the EmailTemplateActorModel.
Below is a snippet from my TinyMCE configuration.
config.For<EmailTemplateActorModel>(t => t.Body)
  .AddPlugin("code")
  .Toolbar(new[] { defaultToolbarTop, "code" });
The error I get is: There is no implicit reference conversion from 'EPiServer.Forms.Implementation.Actors.EmailTemplateActorModel' to 'EPiServer.Core.IContentData'.    CapCom.Epi.Cms
Is there any way to accomplish this other than enabling the HTML souce code option for all editor fields?
#300446
Edited, Apr 20, 2023 21:24
The fastest way to overwrite the RTF settings for this specific field can be done using the EditroDescriptor:
    [EditorDescriptorRegistration(TargetType = typeof(XhtmlString))]
    public class EmailTemplateActorCollectionEditorDescriptor : EditorDescriptor
            if (metadata.ContainerType == typeof(EmailTemplateActorModel))
                var settings = (TinyMceSettings)metadata.EditorConfiguration["settings"];
                settings.Toolbar("code");
                //add any other settings
Since EmailTemplateActorModel doesn't inherit from IContentData, you need to override the behavior on the metadata. This is how it should look:
You can also be more specific and manipulate directly the EditorDescriptor that configures the EmailTemplateActorModel which is this:
[EditorDescriptorRegistration(TargetType = typeof(IEnumerable<EmailTemplateActorModel>), UIHint = "EmailTemplateActorEditor")]
public class EmailTemplateActorCollectionEditorDescriptor : CollectionEditorDescriptor<EmailTemplateActorModel>
Hope it helps
Santiago.
#300842
Apr 27, 2023 17:05
Hi Santiago,
Thank you so much. Your code snippet works for modifying the editor descriptor for XhtmlString. When I adapt that to use the more specific selector for IEnumerable<EmailTemplateActorModel> I get errors when calling the base.ModifyMetadata(metadata, attributes) (adding duplicate key) and when accessing the metadata.EditorConfiguration["settings"] property (does not exist). Could you provide please the complete implementation for that specific registration?
Rich
#300897
Apr 28, 2023 14:49
After working with Optimizely support I had to tweak the attribute a bit to make this work.
[EditorDescriptorRegistration(TargetType = typeof(XhtmlString), EditorDescriptorBehavior = EditorDescriptorBehavior.PlaceLast)]
Once I deployed to the INTE environment I was seeing errors that I did not have locally and this solved that issue.
Also, I had to re-apply the TinyMCE configuration to include my default settings.
#303828
Jun 20, 2023 14:02
Hi Rich,
I don't suppose a blog post would be out of the question? to help share the knowledge and your experiences upon this.
Something brief that explains the situtation you where up against, what issues / errors you experienced along the way.
Who helped along the way.
Paul
#303885
Jun 21, 2023 10:26
