Custom form rendering using the built in FormContainerBlock
I'm trying to perform some custom rendering of a form using Epi Forms 5.4.0. I do not want to copy the contents of the FormContainerBlock.cshtml located in the EPiServer.Forms.zip but rather just render the block using what's already there.
This is the controller:
[TemplateDescriptor(AvailableWithoutTag = true,
    ModelType = typeof(LeadsFormBlock))]
public class LeadsFormBlockController : FormContainerBlockController {
    protected override IViewComponentResult InvokeComponent(FormContainerBlock currentBlock) {
        if(currentBlock is LeadsFormBlock leadsFormBlock) {
            var viewModel = new LeadsBlockViewModel { CurrentBlock = currentBlock, OtherProperty = leadsFormBlock.OtherProperty };
            return View("Index", viewModel);
        return base.InvokeComponent(currentBlock);
And the view:
@model LeadsBlockViewModel
<div class="custom-class">
    <h3>This is the wrapping form!</h3>
    <strong>@Model.OtherProperty</strong> @* Works *@
    @Html.PropertyFor(x => x.CurrentBlock) @*Does not work/Renders nothing*@
    @await Html.PartialAsync("FormContainerBlock", Model.CurrentBlock) @*Crashes because cannot find the view*@
</div>
#297861
Edited, Mar 07, 2023 11:16
Mark Stott
Hello Mårten,
The root path to find the forms views is under /FormsViews/ and then it's pretty much as per the structure in the EPiServer.Forms.zip file.  So in the case of the FormContainerBlock you can use the following:
@model MyBuild.Features.Blocks.CustomForm.CustomFormBlock
<div>
    <h2>Hello World</h2>
    @await Html.PartialAsync("~/FormsViews/Views/ElementBlocks/Components/FormContainerBlock/FormContainerBlock.cshtml", Model);
</div>
#298058
Mar 10, 2023 15:19
Thank you Mark! :)
#298651
Mar 20, 2023 14:04
