You will need to setup a development index, this can be done at https://find.episerver.com/
I did this and the error no longer shows, but nothing shows up under the Mens and Womens clothing categories and catalog pages
Your index is initially empty. You will need to Re-index the catalog by going to CMS > Admin > Find Content Indexing job. Once you run it your search index will be populated with the entries. You can check if by going to the top navigation menu, selecting Search & Navigation > Overview
Lika Aniket pointed out, navigate to the admin interface » scheduled jobs » Search & Navigation Content Indexing Job » start manually
It is also a good idea to check your preferred settings here
I have a Foundation project working and basically everything works except when I try to view a Catalog (i.e https://localhost:5001/en/fashion/mens/mens-shoes/). I know I need to modify the appsettings.json "changeme" values - I have
Initial
"EPiServer": {
"Find": {
"DefaultIndex": "changeme",
"ServiceUrl": "http://changeme",
"TrackingSanitizerEnabled": true,
"TrackingTimeout": 30000
System.Net.Dns.GetHostEntryOrAddressesCore(string hostName, bool justAddresses, AddressFamily addressFamily, ValueStopwatch stopwatch)
System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(string host, int port, HttpRequestMessage initialRequest, bool async, CancellationToken cancellationToken)
System.Net.HttpWebRequest.GetResponse()
EPiServer.Find.Api.Command.GetResponse<TResult>(IJsonRequest request)
Tried to change to:
or
System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
