CMS/Commerce Upgrade deployment to Integration
HI Folks,
I am deploying the upgraded CMS 12/Customized Commerce 14 website to DXP and running into the following issue. The deployment goes through but the website doesn't load and shows the following error.
Any suggestions?
  Ok
2023-12-01T04:02:19.0932931
https://aka.ms/dotnet/app-launch-failed
  Ok
2023-12-01T04:02:19.0932967
  Ok
2023-12-01T04:02:19.0932999
To install missing framework, download:
  Ok
2023-12-01T04:02:19.0933035
https://aka.ms/dotnet-core-applaunch?framework=Microsoft.WindowsDesktop.App&framework_version=6.0.0&arch=x64&rid=debian.11-x64
  Ok
2023-12-01T04:02:19.0935312
Failed to start application Project.Website.CMS.dll: 150
  Ok
  Ok
2023-12-01T04:06:47.0929267
Starting ssh...
  Ok
2023-12-01T04:06:47.1225414
Starting OpenBSD Secure Shell server: sshd.
  Ok
2023-12-01T04:06:47.1227016
Starting application...
  Ok
2023-12-01T04:06:47.1252215
You must install or update .NET to run this application.
  Ok
2023-12-01T04:06:47.125234
  Ok
2023-12-01T04:06:47.1252368
App: /app/Project.Website.CMS.dll
  Ok
2023-12-01T04:06:47.125301
Architecture: x64
  Ok
2023-12-01T04:06:47.1254043
Framework: 'Microsoft.WindowsDesktop.App', version '6.0.0' (x64)
  Ok
2023-12-01T04:06:47.1254395
.NET location: /usr/share/dotnet/
  Ok
2023-12-01T04:06:47.1254818
  Ok
2023-12-01T04:06:47.1255478
No frameworks were found.
  Ok
2023-12-01T04:06:47.1256637
  Ok
2023-12-01T04:06:47.1256701
Learn about framework resolution:
  Ok
2023-12-01T04:06:47.1256726
  Ok
2023-12-01T04:06:47.1256748
  Ok
2023-12-01T04:06:47.125677
  Ok
2023-12-01T04:06:47.1257112
  Ok
2023-12-01T04:06:47.1260099
  Ok
  Ok
2023-12-01T04:11:14.474174
Starting ssh...
  Ok
2023-12-01T04:11:14.50921
  Ok
2023-12-01T04:11:14.50923
  Ok
2023-12-01T04:11:14.5116887
  Ok
2023-12-01T04:11:14.511722
  Ok
2023-12-01T04:11:14.5117272
  Ok
2023-12-01T04:11:14.5117315
Architecture: x64
  Ok
2023-12-01T04:11:14.5117352
  Ok
2023-12-01T04:11:14.5117396
  Ok
2023-12-01T04:11:14.5117429
  Ok
2023-12-01T04:11:14.5117461
  Ok
2023-12-01T04:11:14.5117494
  Ok
2023-12-01T04:11:14.5117526
  Ok
2023-12-01T04:11:14.5117561
  Ok
2023-12-01T04:11:14.5117598
  Ok
2023-12-01T04:11:14.5117631
  Ok
2023-12-01T04:11:14.5117668
  Ok
2023-12-01T04:11:14.5121778
  Ok
  Ok
2023-12-01T04:15:48.1971555
Starting ssh...
  Ok
2023-12-01T04:15:48.2314466
  Ok
2023-12-01T04:15:48.2316784
  Ok
2023-12-01T04:15:48.2361654
  Ok
2023-12-01T04:15:48.2361802
  Ok
2023-12-01T04:15:48.2361844
  Ok
2023-12-01T04:15:48.2361947
Architecture: x64
  Ok
2023-12-01T04:15:48.236232
  Ok
2023-12-01T04:15:48.2362712
  Ok
2023-12-01T04:15:48.2362885
  Ok
2023-12-01T04:15:48.2363823
  Ok
2023-12-01T04:15:48.2365043
  Ok
2023-12-01T04:15:48.2365132
  Ok
2023-12-01T04:15:48.2365172
  Ok
2023-12-01T04:15:48.2365204
  Ok
2023-12-01T04:15:48.2365234
  Ok
2023-12-01T04:15:48.2365321
  Ok
2023-12-01T04:15:48.2368506
  Ok
  Ok
2023-12-01T04:20:19.066142
Starting ssh...
  Ok
2023-12-01T04:20:19.1236495
  Ok
2023-12-01T04:20:19.1236713
  Ok
2023-12-01T04:20:19.1259386
  Ok
2023-12-01T04:20:19.125955
  Ok
2023-12-01T04:20:19.1259601
  Ok
2023-12-01T04:20:19.1259638
Architecture: x64
  Ok
2023-12-01T04:20:19.1259763
  Ok
2023-12-01T04:20:19.1260234
  Ok
2023-12-01T04:20:19.1260347
  Ok
2023-12-01T04:20:19.1260707
  Ok
2023-12-01T04:20:19.1262827
  Ok
2023-12-01T04:20:19.126293
  Ok
2023-12-01T04:20:19.1262967
  Ok
2023-12-01T04:20:19.1263
  Ok
2023-12-01T04:20:19.1263039
  Ok
2023-12-01T04:20:19.1263074
  Ok
2023-12-01T04:20:19.1264986
  Ok
  Ok
2023-12-01T04:24:44.0865119
Starting ssh...
  Ok
2023-12-01T04:24:44.1188213
  Ok
2023-12-01T04:24:44.1189372
  Ok
2023-12-01T04:24:44.1216987
  Ok
2023-12-01T04:24:44.1217288
  Ok
2023-12-01T04:24:44.1217335
  Ok
2023-12-01T04:24:44.121737
Architecture: x64
  Ok
2023-12-01T04:24:44.1217405
  Ok
2023-12-01T04:24:44.1217449
  Ok
2023-12-01T04:24:44.1217489
  Ok
2023-12-01T04:24:44.1217524
  Ok
2023-12-01T04:24:44.1217562
  Ok
2023-12-01T04:24:44.1217595
  Ok
2023-12-01T04:24:44.121763
  Ok
2023-12-01T04:24:44.1217666
  Ok
2023-12-01T04:24:44.1217699
  Ok
2023-12-01T04:24:44.1217737
  Ok
2023-12-01T04:24:44.122036
#313490
Dec 01, 2023 4:48
You should be able to get the detailed log on the PaaS portal on why the application failed to start
#313502
Dec 01, 2023 9:15
Nothing from the logs. It keeps throwing the same error. I am guessing I haven't configured the pipeline correctly?
023-12-02T06:55:08.376383397Z Starting ssh...
2023-12-02T06:55:08.435721762Z Starting OpenBSD Secure Shell server: sshd.
2023-12-02T06:55:08.436108367Z Starting application...
2023-12-02T06:55:08.440788319Z You must install or update .NET to run this application.
2023-12-02T06:55:08.440801919Z
2023-12-02T06:55:08.440806019Z App: /app/Project.Website.CMS.dll
2023-12-02T06:55:08.440878220Z Architecture: x64
2023-12-02T06:55:08.440994421Z Framework: 'Microsoft.WindowsDesktop.App', version '6.0.0' (x64)
2023-12-02T06:55:08.441048322Z .NET location: /usr/share/dotnet/
2023-12-02T06:55:08.441086322Z
2023-12-02T06:55:08.441252824Z No frameworks were found.
2023-12-02T06:55:08.441282725Z
2023-12-02T06:55:08.441287725Z Learn about framework resolution:
2023-12-02T06:55:08.441292125Z https://aka.ms/dotnet/app-launch-failed
2023-12-02T06:55:08.441295625Z
2023-12-02T06:55:08.441299125Z To install missing framework, download:
2023-12-02T06:55:08.441306425Z https://aka.ms/dotnet-core-applaunch?framework=Microsoft.WindowsDesktop.App&framework_version=6.0.0&arch=x64&rid=debian.11-x64
2023-12-02T06:55:08.441706229Z Failed to start application RF.Website.CMS.dll: 150
#313563
Edited, Dec 02, 2023 7:01
I'd suggest to contact developer support service, they should be able to help out with this
#313564
Dec 02, 2023 9:44
Hi Aniket
Did you target you projects on net6.0-windows? DXP for CMS 12 is hosted in Linux container, so you need to make sure you application is fully running on Linux first. If you have any dependencies that requires to be running on Windows, you'll need to find alternative.
#313638
Dec 03, 2023 23:57
Thakns Vincent.
To close the loop here it was infact related to the net6.0-windows issue. We had a nuget package that was referencing a Windows depended Winforms/WPF. We removed that package and changed the target framework to net6.0 (no -windows) in the csproj file. That resolved the issue.
#314031
Dec 11, 2023 2:07
