From memory, most of marketing connectors only support standard objects with default simple type fields.
i don't see an easy way to customise connector to achieve your desired result. Think broadly, in order to achieve what you want, you need to customize connector, then form element for handling complex type etc
I suggest you contact Optimizely support to see if there is any alternative.
Hello Team,
We are using Optimizely CMS v12.15 and Salesfrce connector EPiServer.MarketingAutomationIntegration.Salesforce v5.1.2.
In the "Extra field mappings" dropdown I cannot see pickvalue fields, it's showing only simple data types. Is it not supported? If not, is there any work around?
Olga
