Is there a way to give a character limit to XHTMLString and strings?
At the moment our client is experiencing an issue when translating content using a third party plugin, which says that "The field Title must be a string or array type with a maximum length of '50'"
Is there any Data Annotation that i could use on a XHTMLString/String or would i need to create my own Validation method?
Thanks!
#310778
Edited, Oct 13, 2023 12:42
You can use System.ComponentModel.DataAnnotations.StringLengthAttribute for string properties. But for XhtmlString properties you would need to roll your own validator.
#310820
Oct 14, 2023 6:01
I've blogged on this a while ago, https://www.herlitz.io/2022/12/21/validate-optimizely-xhtmlstring-property-length/
It'll enable you to have a minimum amount of characters as well as a maximum amount.
[Display(Name = "MainContent")]
[Required]
[XhtmlStringLengthValidation(50, 500, CustomErrorMessage = "The Main content field must contain more than {0} characters but less than {1}.")]
public virtual XhtmlString MainContent{ get; set; }
It should as well only count text characters not including the markup.
#310899
Oct 16, 2023 8:45
