Assemblies have not been updated with the current database version.
Hello!
Running on EPiServer.CMS 11.20.12, we've encountered a problem. When we try to run the site we get the following error: "The assemblies for 'CMS' have not been updated to work with the current database version '7072.0'. Supported database version is '7070.0'."
We've tried to run the "Update-EPiDatabase" command but without success. I'm guessing that's because the database is not behind, but rather a nuget. Is "CMS" pointing to the EPiServer.Cms.Core-package? Or is it something else that might cause this error?
#310096
Oct 05, 2023 10:56
Yes, it's the cms.core package. and yes it's the database is "newer" than the assembly. did you sync your database from somewhere else?
#310100
Oct 05, 2023 11:41
I'm working with Sebastian and we managed to solve it and it turned out to have a simple solution. The database schema for a shared DB had accidentally been upgraded through a nuget upgrade. I thought the problem could be resolved with update-epidatabase, but the script can't downgrade only upgrade.
I updated cms.core and its dependencies until we were once more compatible with the database to resolve the issue. Feels a bit silly in hindsight, thanks for the aid! :)
#310152
Oct 06, 2023 8:03
Tomas Hensrud Gulla
I always prefer to have this locally...
<episerver.framework updateDatabaseSchema="false">
...to avoid unintentional upgrading the database schema.
In integration/preproduction/production, I leave it on true.
#310170
Oct 06, 2023 20:12
