I see that I am able to step in couple of initialization modules and then it abrutly exits and i see exception as mentioned above. However this goes through fine on a new database. How can I check the dependency that is causing the null exception.
Hey,
I hope you followed proper steps to upgrade. But there are plenty of blogs that may help you in investigate the issue.
https://optimizely.blog/2021/11/upgrading-episerver-cms-11-to-optimizely-cms-12-porting-to-net-5/
Do you have explicit GUIDs declared on your content types? I had an issue with that when doing an upgrade a few months ago. I had to go into the CMS11 version, add GUIDs and publish. Then in the CMS12 version, I reused the same GUIDs for the CMS12 version of the content types there.
I was having issues with latest version where DB version was 8011. I did downgrade assemblies couple minor version to where it uses 8009 version of database and that helped resolved the issue. I will research later on why the latest version was throwing error.
I am upgrading a solution from CMS 11 to 12. After ensuring all content types are available in new solution, I am able to launch the site with a brand new empty database. However when I switch to existing database which I had with CMS 11, I am getting initialization error. What could I be missing. I tried to debug through initialization modules but couldn't find anything relevant
===> 22:50:25 [Error] Initialize action failed for 'Initialize on class EPiServer.Initialization.Internal.ModelSyncInitialization, EPiServer, Version=12.11.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'
System.AggregateException: One or more errors occurred. (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.)
---> System.NullReferenceException: Object reference not set to an instance of an object.
at EPiServer.DataAbstraction.RuntimeModel.Internal.ContentTypeModelRegister.ValidateChangeOfModelType(PropertyDefinitionModel propertyModel, String modelName)
at EPiServer.DataAbstraction.RuntimeModel.Internal.ContentTypeModelRegister.SetStateForPropertyDefinitionModels(ContentTypeModel model)
at EPiServer.DataAbstraction.RuntimeModel.Internal.ContentTypeModelRegister.<AnalyzeProperties>b__15_0(ContentTypeModel model)
at System.Threading.Tasks.Parallel.<>c__DisplayClass33_0`2.<ForEachWorker>b__0(Int32 i)
at System.Threading.Tasks.Parallel.<>c__DisplayClass19_0`1.<ForWorker>b__1(RangeWorker& currentWorker, Int32 timeout, Boolean& replicationDelegateYieldedBeforeCompletion)
--- End of stack trace from previous location ---
at System.Threading.Tasks.TaskReplicator.Replica.Execute()
at System.Threading.Tasks.TaskReplicator.Run[TState](ReplicatableUserAction`1 action, ParallelOptions options, Boolean stopOnFirstFailure)
at System.Threading.Tasks.Parallel.ForWorker[TLocal](Int32 fromInclusive, Int32 toExclusive, ParallelOptions parallelOptions, Action`1 body, Action`2 bodyWithState, Func`4 bodyWithLocal, Func`1 localInit, Action`1 localFinally)
at System.Threading.Tasks.Parallel.ThrowSingleCancellationExceptionOrOtherException(ICollection exceptions, CancellationToken cancelToken, Exception otherException)
at System.Threading.Tasks.Parallel.ForEachWorker[TSource,TLocal](IList`1 list, ParallelOptions parallelOptions, Action`1 body, Action`2 bodyWithState, Action`3 bodyWithStateAndIndex, Func`4 bodyWithStateAndLocal, Func`5 bodyWithEverything, Func`1 localInit, Action`1 localFinally)
at System.Threading.Tasks.Parallel.ForEachWorker[TSource,TLocal](IEnumerable`1 source, ParallelOptions parallelOptions, Action`1 body, Action`2 bodyWithState, Action`3 bodyWithStateAndIndex, Func`4 bodyWithStateAndLocal, Func`5 bodyWithEverything, Func`1 localInit, Action`1 localFinally)
at System.Threading.Tasks.Parallel.ForEach[TSource](IEnumerable`1 source, Action`1 body)
at EPiServer.DataAbstraction.RuntimeModel.Internal.ContentTypeModelRegister.AnalyzeProperties()
at EPiServer.DataAbstraction.RuntimeModel.Internal.ContentTypeModelScanner.Sync(Boolean forceCommit)
at EPiServer.Initialization.Internal.ModelSyncInitialization.Initialize(InitializationEngine context)
at EPiServer.Framework.Initialization.Internal.ModuleNode.Execute(Action a, String key)
at EPiServer.Framework.Initialization.Internal.ModuleNode.Initialize(InitializationEngine context)
at EPiServer.Framework.Initialization.InitializationEngine.InitializeModules()
---> (Inner Exception #1) System.NullReferenceException: Object reference not set to an instance of an object.
at System.Threading.Tasks.TaskReplicator.Replica.Execute()<---
===> 22:50:25 [Error] Begin Startup Failed Message
===> 22:50:27 [Fatal] End Startup Failed Message
EPiServer.Framework.Initialization.InitializationException: Initialize action failed for Initialize on class EPiServer.Initialization.Internal.ModelSyncInitialization, EPiServer, Version=12.11.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7
---> System.AggregateException: One or more errors occurred. (Object reference not set to an instance of an object.) (Object reference not set to an instance of an object.)
at EPiServer.Framework.Initialization.InitializationEngine.ExecuteTransition(Boolean continueTransitions)
at EPiServer.Framework.Initialization.InitializationEngine.Initialize()
at EPiServer.Hosting.Internal.EPiServerFrameworkHost.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)
at Produce.Web.Program.Main(String[] args) in C:\2.IFPAUpg\dev\src\Web\Program.cs:line 40
