EPiServer urlResolver.GetUrl(pageLink) returns absolute URL (randomly)
ZZ
ZZ
We have an issue with one of our environment that urlResolver.GetUrl(pageLink) returns https://xx.dk/ttps:/xx.dk/toppage/yy-page, which causes problems for our customers when one page redirects to another page, it happens randomly so this doesn't happen everytime.
In another example when the publish event is called the absolute URI is returned
Here urlResolver.GetUrl(xx) returns absolute URL all the times on only one environment, but not on other envirnments -> new Uri(BaseUrl + urlResolver.GetUrl(xx))
Any input would be appreciated
 private static void ContentEventsOnPublishedContent(object sender, ContentEventArgs contentEventArgs)
            try
                lock (Lock)
                    if (!(contentEventArgs.ContentLink is PageReference)) return;
                    var urlResolver = _urlResolver.Service;
                    using (var test = new XX())
                        test.Crawl(new Uri(BaseUrl + urlResolver.GetUrl(contentEventArgs.ContentLink));
            catch (Exception e)
                Logger.Error("Error during publish of page", e);
#282236
Jun 22, 2022 8:48
This is normally due to host settings in admin if I remember correctly. Make sure you have correct domain etc configured for the website.
If these are not correct you will have issues when changing language in edit (which uses this) and UrlResolver (especially when no HttpContext is available like in scheduled jobs)
#282245
Edited, Jun 22, 2022 12:06
The URL format depends on the context - is there an http context available, are you trying to resolve an URL to a page on another site (given you a multi-site setup), your website + host settings, etc.
You can pass in arguments to the resolver and enforce an absolute URL, then parse it as an URI. Then you can decide how you want to use that URI, e.g. if you just want to use the path component of it.
#282255
Jun 22, 2022 14:30
ZZ
Thanks a lot for the responses.
We have double binding in IIS https://xx.dk & https://www.xx.dk
In EPiServer admin config URL is set to "https://xx.dk/"  & Host names is set to ->
Host Name Culture Type
xx.dk da Primary
We are gettting this type of URL when some page is publised : https://www.xx.dkhttps/xx.dk/parentPage1/parentPage2/test/
#282421
Edited, Jun 24, 2022 13:40
ZZ
I found the issue, it was our Rely Party URL (ADFS login) which contained www now we have changed it to https://xx.dk and it works fine.
#282835
Jul 01, 2022 12:16
