How to generate internal link for ContentReference?
Ian
Ian
Optimizely
If I have a valid ContentReference instance pointing to a block, how can I go about getting the internal URL for that block? Example: ~/link/dd34112844b94401a0c66ed8106ae4cb.aspx
#277080
Mar 24, 2022 15:42
Ian
I haven't found a method yet that will do it, but this will effectively output the same format:
 var internalUrl = $"~/link/{block.ContentGuid.ToString().Replace("-", "")}.aspx";
#277082
Mar 24, 2022 16:20
Hi Ian,
I would be interested in understanding what you are trying to do, why do you want to create a url for a block, as they are not routable?
Andy
#277208
Mar 25, 2022 20:20
Tomas Hensrud Gulla
Have a look at my blogpost for varius ways of obtaining the URL.
https://www.gulla.net/no/blog/content-url-with-or-without-shortcut/
My favorite:
SELECT LinkURL
FROM tblContentLanguage
WHERE fkContentID = 1337
#277245
Edited, Mar 26, 2022 18:24
The official way is to use IPermanentLinkMapper to get the PermanentLinkMap from ContentReference (_permanentLinkMapper.Find(contentLink). PermanentLinkMap  contains PermanentLinkUrl which should be what you are looking for :)
#277341
Mar 28, 2022 15:21
Ian
@Andrew - The short of it is that I'm allowing editors to link to certain block types from within the Create Link dialog window, which will result in a dynamic modal popup window on the front-end. In doing so, I need to override the UrlResolver so that the correct URLs are generated on both the front-end as well as the Epi admin.
#277342
Mar 28, 2022 17:20
