How to access a Json file as an endpoint ?
I am working on a .Net application comnined with Optimizely CRM. i would like to access a json file like
www.abc.com/.well-known/assetlinks.json
but i can able to accress from local like
https://localhost:44300/.well-known/assetlinks.json
but wehen i try to deploy in the test environment i get this error
404 not found
Any help would be highly appricited.
#276801
Mar 21, 2022 14:37
Tomas Hensrud Gulla
Have  you checked if the json file is present in the test environment?
#276844
Mar 22, 2022 7:40
I think the most likely reason is, as Tomas suggests, that the file hasn't been deployed for some reason but, if the file is there and you're still getting a 404, it could be an issue with mime type mappings. If you're on .net 4.x, you can add a mapping for the file type in web.config like this:
<staticContent>
  <remove fileExtension=".json" />
  <mimeMap fileExtension=".json" mimeType="application/json" />
</staticContent>
If you're on .net >= 5, you'll need to add your mapping in your startup class using app.UseStaticFiles.
#276846
Mar 22, 2022 9:57
Rashed - Mar 22, 2022 14:43
thanks. this piece of code really worked well.
