GetaEpiCategories with CMS 12
Hello All,
I am trying to use Geta Epi Categories in CMS 12.  My solution targets .NET 6. After installation when I run, I get errors on start up as Failed to scan some types (Failed to load types from Geta.EpiCategories) . In the event viewer i see its looking for Episerver.Framework.AspNet version 11.9.0.0.
I did create a type deriving from CategoryData.
Is there anything am missing. Trying to install latest version 1.2.11
Am using Geta categories for first time and from documentation, I don't think I missed any step. Does this not work with CMS 12 as I see its looking for assemblies listed below
System.AggregateException: Failed to scan some types (Failed to load types from Geta.EpiCategories)
 ---> EPiServer.Framework.TypeScanner.TypeScannerReflectionException: Failed to load types from Geta.EpiCategories
 ---> System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types.
Could not load file or assembly 'EPiServer.Framework.AspNet, Version=11.9.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'. The system cannot find the file specified.
Could not load file or assembly 'EPiServer.Cms.AspNet, Version=11.9.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'. The system cannot find the file specified.
Could not load file or assembly 'System.Web.Mvc, Version=5.2.3.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. The system cannot find the file specified.
#293000
Dec 11, 2022 21:22
Dec 12, 2022 7:25
Mark Powney on Twitter: "Out of all the #MicrosoftTeams ...
Thank you Karol. I should have scrolled more . :)
#293042
Dec 12, 2022 21:10
