So I found the solution to my own problem, had to do it "the hard way" since this functionality hasn't been supported yet.
Basically I intercepted the postMixInProperties event of the PageNavigationTree. In that event I got the context menu commands by using the _contextMenuCommandProvider, reordered these commands, and set the new value back, still by using the _contextMenuCommandProvider. The result looks like this:
We need a module initializer to be able to do this, go to this page if you haven't configured one. Here's my module initializer for the POC:
define([
"dojo",
"dojo/_base/declare",
'dojo/_base/array',
"epi/_Module",
"epi-cms/plugin-area/navigation-tree",
"alloy/Command/CustomCommand",
'epi-cms/component/PageNavigationTree',
'epi-cms/command/NewContent'
], function (dojo,
declare,
array,
_Module,
navigationTreePluginArea,
CustomCommand,
PageNavigationTree,
NewContentCommand
return declare("alloy.moduleInitializer", [_Module], {
initialize: function () {
this.inherited(arguments);
// Do any custom module initialization here
// Add Custom Command button to the Navigation Tree
navigationTreePluginArea.add(CustomCommand);
// Customize PageNavigationTree
var originalPostMixInProperties = PageNavigationTree.prototype.postMixInProperties;
// Extends the original postMixInProperties
PageNavigationTree.prototype.postMixInProperties = function () {
// call the original function
originalPostMixInProperties.apply(this, arguments);
//getting the context menu commands
var customCommands = this._contextMenuCommandProvider.get("commands");
// updating the style, since I wanted to group My Custom Command with the New Page command, so I updated New Page command to a normal menu item style, and I updated My Custom Command to a menu item with a separator.
var customCmdIndex = 0;
var newContentCmdIndex = 0;
array.forEach(customCommands,
function (command, i) {
if (command instanceof NewContentCommand) {
newContentCmdIndex = i;
command.category = 'context';
} else if (command instanceof CustomCommand) {
customCmdIndex = i;
command.category = 'menuWithSeparator';
// moving My Custom Command to right under the New Page Command
customCommands.splice(newContentCmdIndex + 1, 0, customCommands.splice(customCmdIndex, 1)[0]);
this._contextMenuCommandProvider.set("commands", customCommands);
I followed this official documentation to put my own command into the context menu of the Navigation Tree. However my component appears at the bottom of the menu, while I want it to be displayed right under the "New Page" command (just for UX purpose).
The instruction only tells me to put this line of code into my module initializer:
I couldn't find any options to change the order of My Custom Command. Is there any way to achieve that?
Regards,
Tung
