One thing suggested in another thread here is adding this to your Startup.cs:
services.Configure<FormOptions>(x =>
x.MultipartBodyLengthLimit = 10737418240;
Another possibility (also from that thread) is setting the max size for kestrel:
public static IHostBuilder CreateHostBuilder(string[] args) =>
Host.CreateDefaultBuilder(args)
.ConfigureWebHostDefaults(webBuilder =>
webBuilder.ConfigureKestrel((context, options) =>
// Handle requests up to 50 MB
options.Limits.MaxRequestBodySize = 52428800;
.UseStartup<Startup>();
Did you happend to find a solution to this issue? Im having the same problem with forms version 5.5.1.
Edit: Solution found.
In the EpiserverForms package the max file size is determined by this (decompiled) method:
private int GetmaxSizeInByte(int fileUploadsize)
int num = (int) ServiceLocator.Current.GetInstance<IHttpContextAccessor>().HttpContext.Features.Get<IHttpMaxRequestBodySizeFeature>().MaxRequestBodySize.Value;
int multipartBodyLengthLimit = (int) this._formsOptions.MultipartBodyLengthLimit;
return ((IEnumerable<int>) new int[3]
fileUploadsize,
num,
}).Min();
Hello everyone!
