Yes just add a new property to your SitePageData model that's a boolean and then adjust the Search & Navigation code to only search for pages where it's set to true using the Match() method https://world.episerver.com/documentation/Items/Developers-Guide/EPiServer-Find/11/DotNET-Client-API/Searching/Filtering/Boolean/
Thanks Scott for your suggestion, so I have gone ahead and added a boolean to our SitePageData.cs model:
[Display(
GroupName = SystemTabNames.Settings,
Order = 351)]
public virtual bool ExcludeFromSearch { get; set; }
Then in FindSearchPageController.cs I attempted to adjust the search by adding a filter as suggested in the example you posted:
private ITypeSearch<ISearchableContent> BuildQuery(FindSearchContentModel model, string language)
var searchQuery = searchClient.Search<ISearchableContent>()
.For(model.Query)
.InField(x => x.Name)
.InAllField()
.UsingAutoBoost(TimeSpan.FromDays(30))
.Filter(sp => sp.IsDeleted.Match(false))
.Filter(x => x.ExcludeFromSearch.Match(false))
.FilterForVisitor()
.Filter(x => x.SearchLanguage.Match(language) | x.SearchLanguage.Match(string.Empty))
.TermsFacetFor(x => x.SearchSection())
.FilterFacet("AllSections", x => x.SearchSection().Exists())
.TermsFacetFor(x => x.SearchTags)
.FilterFacet("AllTags", x => x.SearchTags.Exists())
.TermsFacetFor(x => x.SearchCategory)
.FilterFacet("AllCategories", x => x.SearchCategory.Exists());
if (!string.IsNullOrWhiteSpace(model.SectionFilter))
searchQuery = searchQuery.Filter(x => x.SearchSection().Match(model.SectionFilter));
if (!string.IsNullOrWhiteSpace(model.FilterByTags))
searchQuery = searchQuery.Filter(x => x.SearchTags.Match(model.FilterByTags));
if (!string.IsNullOrWhiteSpace(model.Category))
searchQuery = searchQuery.Filter(x => x.SearchCategory.Match(model.Category));
searchQuery = Sort(searchQuery, model.SortBy)
.Skip((model.PagingPage - 1) * model.CurrentPage.PageSize)
.Take(model.CurrentPage.PageSize)
.ApplyBestBets();
var doNotTrackHeader = System.Web.HttpContext.Current.Request.Headers.Get("DNT");
// Should not track when value equals 1
if (doNotTrackHeader == null || doNotTrackHeader.Equals("0"))
searchQuery = searchQuery.Track();
return searchQuery;
The error I get however is: "ISearchableContent does not contain a definition for ExcludeFromSearch and no accessible extension method ExcludeFromSearch accepting a first argument of type ISearchableContent could be found"
If I look in ISearchableContent I see:
using EPiServer.Core;
using System;
namespace ProjectDigital.Site.Models.Search
public interface ISearchableContent : IContent
DateTime SearchPublishDate { get; }
IEnumerable<string> SearchTags { get; }
IEnumerable<string> SearchCategory { get; }
string TeaserText { get; }
ContentReference PageImage { get; }
string SearchLanguage { get; }
IEnumerable<string> SearchBreadcrumbs { get; }
Apologies I am new to this all. Do you have any suggestion for me perhaps?
You need to add ExcludeFromSearch to the Interface.
using System;
bool ExcludeFromSearch {get;}
Thank you so much for your help Scott, I assume I will have to rebuild the find index for this to work correct?
Hi there,
I would like to add the ability for our editors to be able to hide certain pages from appearing in the site-wide search.
What would be the best way to go about doing this?
Let's say I edit our model for SitePageData.cs from which all our pages inherit and add a boolean like so: public virtual bool HidePage { get; set; }
How could I access this boolean from the Search Query?
