how to update and existing block
Its been a while I workd on EPIserver and cannot recollect on how to update an existing block, I have the model updated, but it wont reflect in the CMS. I remeber something was updated on the tblCotnetnType folder, but cant recollect. Can any one help me on this
#248902
Feb 20, 2021 18:32
Just want to understand, You are saying you have updated the Block Type model but new properties are not appearing in cms?
I assume you are updating from Code.
#248905
Feb 20, 2021 20:25
Yes that's correct, Not sure if we need to do anything so it shows up in the CMS
#248907
Feb 20, 2021 22:19
Hemanth
There few options i can suggest
1 - if you are using DXP while deploying, if you update module changes its best to  "use the Maintenance page" option. That helps you to sync your cms with the database.
2 - Its the work around I use - When I deploy and new properties are reflecting in page type/block type in cms. I normally go to cms -> Admin -> Content types -> select-your-content-type
Check if your property is not there, then try to create a test property from the interface (you can delete this property later). That will force cms to sync with the database and it will start showing your properties.
Hope that helps
#248908
Feb 20, 2021 22:28
Naveed, Thanks for your input.
Strange no mattter how I add the property, I dont see it in  cms -> Admin -> Content types -> my-content-type.
Is there something else which I can do to view the new block created property.
#248909
Feb 20, 2021 22:54
Have you tried restarting your webapp?
Can you share the code of your new property?
Just to be sure - you can see content type but new property is not available?
#248929
Feb 20, 2021 23:55
