Deleting SQL users in bulk
ZZ
ZZ
Is it possbile to delete SQL users (in bulk) in EPiServer. I can delete one by one but we have a lot of inactive users which I want to delete in bulk.
May be some sql query ?
#267920
Dec 06, 2021 12:17
Scott Reed
You could do it in a SQL query for sure but if it's an ongoing problem and you want to delete regularlly inactive users I'd suggest just build a scheduled job and doing it via code.
#267923
Dec 06, 2021 14:35
ZZ
Thanks for your reply
Do you have any query to do it ?
It will not be an ongoing problem as we are moving to AD and no user would be create directly in EPiServer DB.
#267924
Dec 06, 2021 14:42
Scott Reed
It's just SQL Membership, this is the structure to delete a single user by the unique identifer of the user. So just write a SQL script to pull the users out based on whatever criteria you want and run this for each
DECLARE @UserId uniqueidentifier
SET @UserId = 'GUID_for_UserId'
DELETE FROM aspnet_Profile WHERE UserID = @UserId
DELETE FROM aspnet_UsersInRoles WHERE UserID = @UserId
DELETE FROM aspnet_PersonalizationPerUser WHERE UserID = @UserId
DELETE FROM dbo.aspnet_Membership WHERE UserID = @UserId
DELETE FROM aspnet_users WHERE UserID = @UserId
#267925
Dec 06, 2021 14:47
ZZ
Thanks a lot
#267926
Dec 06, 2021 14:48
If you want a DELETE with a WHERE clause: this is standard SQL.
What you can do is batch deletes like this:
SELECT 'Starting' --sets @@ROWCOUNT WHILE @@ROWCOUNT <> 0 DELETE TOP (xxx) MyTable WHERE ...
Or if you want to remove a very high percentage of rows...
SELECT col1, col2, ... INTO #Holdingtable
           FROM MyTable WHERE ..opposite condition.
TRUNCATE TABLE MyTable
INSERT MyTable (col1, col2, ...)
           SELECT col1, col2, ... FROM #Holdingtable
I
#268043
Dec 08, 2021 13:08
ZZ
Is there any way to do it via UI / admin site ?
#268196
Dec 10, 2021 15:36
- Dec 10, 2021 15:37
not that I'm aware of
