You can get the ContentReference to the current site's StartPage with the static ContentReference member StartPage:
https://www.jondjones.com/learn-episerver-cms/episerver-developers-tutorials/episerver-api-explained/how-to-get-a-reference-to-the-start-page-or-root-page/
Then, use a IContentRepository instance to get the start page content and retrieve the property's value. Since IContentRepository caches content instances it shouldn't be an expensive operation to get the start page, but you can do your own caching if you're worried about it.
var startPageRef = ContentReference.StartPage;
var repo = ServiceLocator.Current.GetInstance<IContentRepository>(); // of course you should always prefer Constructor Injecting dependencies instead of using the ServiceLocatory anti-pattern
var startPage = repo.Get<StartPage>(startPageRef);
var isFoo = startPage.HideLanguageSwitcher;
As for where to do this lookup, you have several options.
You could do it in the view for the header, but some people would say that's too much code in a view.
You could create a base ViewModel that implements your IPageViewModel and add a property to that that holds the language switcher switch. I've seen people implement an action filter for OnResultExecuting that adds properties to the current view model or even the base page type wrapped in an IViewModel right before the view is executed.
You could also implement a partial controller that creates a custom ViewModel just for the header.
I'm sure there are other ways, too.
Thank you very much for your feedback Drew. I am trying to place this in the Header.cshtml right now.
But for
I am getting the following error:
'StartPage' is an ambiguous reference between 'Project.Site.Models.Pages.StartPage' and 'System.Web.WebPages.StartPage'
I have tried rather simply to just write out the full path:
var startPage = repo.Get<Project.Site.Models.Pages.StartPage>(startPageRef);
Not sure if it's the correct way to deal with an exception like this, but it works.
When you are loading data, and not making updates, you could use IContentLoader istead of IContentRepository.
@EpiNewbie
That's correct. In a view file you can also add a using declaration at the top like:
@using Project.Site.Models.Pages
This lets the compiler know that any type names in the Project.Site.Models.Pages should be made available without their fully qualified name. You can also add an import statement to the web.config in your project's Views folder.
https://stackoverflow.com/questions/3239006/how-do-i-import-a-namespace-in-razor-view-page
Of course, @Thomas is correct and since you are not saving, an injected IContentLoader will provide the same functionality as IContent Repository.
In our header we have a language switcher that allows visitors to choose to view a page in one of the available languages, for example EN or DE.
I have created a property in our Startpage.cs model under SiteSettings which I have called HideLanguageSwitcher:
Our Header.cshtml view is using the following as the model:
I am having a hard time understanding how to pass the state of the HideLanguageSwitcher boolean from the Startpage model to Header.cshtml.
In PHP with which I am a little more familiar I would have used a global variable.
Any help greatly appreciated.
