Hide EpiServer gadgets and dashboard
Hi im working on a project where I wanna use episervers on page editing for a page but want to hide the dashboard and gadgets so the user experince is that they are not inside episerver. Any idea how I can hide the dashboard and all gadgets?
I tried The IViewTransformer and that worked for some gadgets, but I want to hide everything.
#264559
Oct 05, 2021 18:01
Scott Reed
Upgrading to .NET 5 is a solution as the dashboard and gadgets have been completely removed in CMS 12 and Commerce 14
#264577
Oct 05, 2021 20:49
David, which components were not possible to remove via transformer? You should be able to remove everything.
Just to make sure we are on the same page - you would like to hide the pagetree, assets pane, projects pane, navigation etc. and only want the main area to be visible right?
You should be able to create a new composite view with only the epi-main-content ContentPane that has OnPageEditing component inside itself.
#265058
Oct 14, 2021 8:02
