How to retrieve not shared properties?
In Episerver exists shared properties between all languages and can only be edited in the master language.
How to detect if property is shared in C#?
#228540
Sep 29, 2020 6:49
Ravindra S. Rathore
You can check it using the below code
 var contentTypeRepository = ServiceLocator.Current.GetInstance<IContentTypeRepository>();
            var blockTypeList = contentTypeRepository.List().OfType<PageType>().ToList();
            List<PageType> newlist = new List<PageType>();
            if (blockTypeList != null && blockTypeList.Any())
                foreach (var block in blockTypeList)
                    if (block.IsAvailable && string.IsNullOrEmpty(block.Description))
                        newlist.Add(block);
                        foreach (var prop in block.PropertyDefinitions)
                            var isLanguageSpecific = prop.LanguageSpecific;
#228541
Sep 29, 2020 7:44
I think Ravindra's answer would work if you want to check against a content type for language specific properties but, if you're trying to check whether a specific property on a given contentitem is localisable (for example checking within a controller for a given page), you can look at the Property collection on that content item like this:
currentPage.Property["MyPropertyName"].IsLanguageSpecific
#228583
Sep 30, 2020 8:01
