Error in Log file /link/Guid.aspx does not exist
I have this error
"EPiServer.Global : Unhandled exception in ASP.NET
System.Web.HttpException (0x80004005): The file '/link/43F936C99B234EA397B261C538AD07C9.aspx' does not exist.
This doesn't exist in local but only in DXC. I followed some suggestions on this error but nothing has worked out so far. Any idea on how to find what is causing this issue.
This is not a show stopper but it clogs my log file and I cannot see actual logs.
#217018
Feb 12, 2020 22:46
- Feb 14, 2020 7:13
When you say "This doesn't exist in local but only in DXC", you mean error or the linked item? If error only appears in DXP, then, can you try run this job and look into report there?
You can check broken links using Link Validation scheduled job.
https://world.episerver.com/documentation/Items/Tech-Notes/EPiServer-CMS-6/EPiServer-CMS-60/Link-Validation/
For that I think you need your site hosted in IIS (if your site is on local). Then you can see the report to see more details about broken link.
More details about report: https://webhelp.episerver.com/18-5/cms-edit/reports.htm
#217024
Feb 13, 2020 7:25
Dileep D - Feb 13, 2020 14:54
So I ran the link validation job and looked at link status report but could not find the mentioned link. Is there anything else that I need to look into.
