Question with EpiServer Property list
I had a property list with Name and Value. I made a selection factory to display the names to select one item from the property list. Following that I could get the value of the selected item in the UI. Sample code below..
public IEnumerable<ISelectItem> GetSelections(ExtendedMetadata metadata)
if (!_contentLoader.TryGet<HomePage>(ContentReference.StartPage, out var HomePage))
return Enumerable.Empty<ISelectItem>();
return HomePage.BannerAlertBackgroundColors?.Select(x => new SelectItem {Text = x.ColorName, Value = x.ColorHexValue });
This is how I used it in the block:
[SelectOne(SelectionFactoryType = typeof(BannerAlertColorSelectionFactory))]
public virtual string BannerBackgroundColor { get; set; }
I need to expand the property list to add one more item, Ex: Name, Value, Image. But I have to keep the implementation still same. User will be selecting the Name in the CMS. I need to update the selection factory some how to return the entire item so I can access Value and Image both in UI.
Any help is most appreciated.
#211449
Jan 08, 2020 20:29
Tomas Hensrud Gulla
Do you need to see the image in edit mode? If not, do something like this?
return HomePage.BannerAlertBackgroundColors?.Select(x => new SelectItem {Text = x.ColorName + ", " + x.Image.Name, Value = x.ColorHexValue + ":" + x.Image.ContentLink.ID });
#214628
Jan 09, 2020 10:05
Dileep D - Jan 11, 2020 19:00
Thanks Tomas,
This is my planned alternative to fetch details but wanted to see if there's a way I could return the entire object itself to access the properties in the View instead of splitting the value and then read them.
