I'm looking for a solution to add a reverse proxy in place to route traffic to external links and use the domain URL as it's.
This is feasible as mentioned in the following links https://ruslany.net/2014/05/using-azure-web-site-as-a-reverse-proxy/ and https://world.episerver.com/blogs/david-buo/dates/2017/11/support-for-applicationhost-transforms-in-dxc-service/
I've made the changes as said in these links, but it doesn't seems to be working. My changes are below
added applicationHost.xdt file in site folder as below
<?xml version="1.0"?>
<configuration xmlns:xdt="http://schemas.microsoft.com/XML-Document-Transform">
<system.webServer>
<proxy xdt:Transform="InsertIfMissing" enabled="true" preserveHostHeader="false" reverseRewriteHostInResponseHeaders="false" />
</system.webServer>
</configuration>
2. added rewrite rule in config file
<rule name="Proxy" stopProcessing="true">
<match url="^/xyz?(/)?$" />
<action type="Rewrite" url="https://www.google.com" />
</rule>
the above still returns 404 error for http://domainname.com/xyz/, i tried adding route ignore as said in the first link but still no luck. i.e., routes.IgnoreRoute("xyz/"); in global.asax.cs file.
I'm not sure if i'm missing anything. this is very urgent requirement to deliver asap.
Any help is much appreciated.
Suresh
