Redirect in Controller after Authentication
Hi folks,
We have a custom login page in place, quite similar to this one here.
We would like to redirect users to the backend, to be precise to "/EPiServer/CMS".
Currently, the code in the CustomLoginController looks like this:
        [HttpPost]
        [AllowAnonymous]
        [ValidateAntiForgeryToken]
        [ValidateInput(false)]
        public ActionResult LocalLogin(CustomLoginViewModel model)
            if (ModelState.IsValid)
                bool result = uiSignInManager.SignIn(uiUserProvider.Name, model.Username, model.Password);
                if (result)
                    return Redirect(UrlResolver.Current.GetUrl(ContentReference.StartPage));
            ModelState.AddModelError("LoginError", "Login failed");
            return View(Global.CustomLoginView, model);
So we tried different things here to actually redirect to the backend but whatever we do we always get redirected to the StartPage / index page. Things we have tried:
return Redirect(UrlResolver.Current.GetUrl("/EPiServer/CMS"));
return Redirect("/EPiServer/CMS");
//Even those two get ignored and users get redirected to the StartPage
return Redirect("WHATEVER");
return Redirect("http://www.google.com");
Any ideas what we are doing wrong?
Best regards,
Patrick
#196619
Sep 05, 2018 16:58
Sounds strange, can you post a version of the full code that still redirects to start page but shouldn't?
When I tested it worked fine redirecting to /episerver/cms using this test code:
Action:
[HttpPost]
public ActionResult TestRedirect()
    return Redirect("/episerver/cms");
View:
<div>
    @using (Html.BeginForm("TestRedirect", "Test", FormMethod.Post))
        <button type="submit">Test</button>
</div>
(I'm already logged in when doing this, but the outcome should be the same regardless of when you login the user.)
#196634
Edited, Sep 05, 2018 23:38
Here is the full monty.
View:
    <div class="modal">
            @using (Html.BeginForm("LocalLogin", "CustomLogin", FormMethod.Post))
                @Html.AntiForgeryToken()
                <ol class="clearfix">
                    <li>
                        <img src="/util/images/login/DXC_long.svg" alt="logo" class="logo" />
                    </li>
                    <li>
                        <div class="validation-summary text--error">
                            @Html.ValidationSummary()
                        </div>
                    </li>
                    <li>
                        @Html.LabelFor(x => x.Username)
                        @Html.TextBoxFor(x => x.Username)
                    </li>
                    <li>
                        @Html.LabelFor(x => x.Password)
                        @Html.PasswordFor(x => x.Password)
                    </li>
                    <li>
                        <input type="submit" value="Log in" class="epi-button-child-item" />
                    </li>
                    <li>
                        <p class="text--small">
                            <a "#" onclick="toggleCookieText(); return false;">
                                When you log in, cookies will be used.
                            </a>
                        </p>
                        <div id="cookieInfoPanel" class="cookie-information">
                                A cookie containing login information will be sent to your web browser. If you do not want to receive cookies, you will be unable to log into the website.
                            </p>
                        </div>
                    </li>
                </ol>
        </div>
Controller:
namespace A1Digital.Site.Controllers
    public class CustomLoginController : Controller
        private UISignInManager uiSignInManager = ServiceLocator.Current.GetInstance<UISignInManager>();
        private UIUserProvider uiUserProvider = ServiceLocator.Current.GetInstance<UIUserProvider>();
        public ActionResult Index()
            return View(Global.CustomLoginView);
        [HttpPost]
        [AllowAnonymous]
                if (result)
Moreover, when taking a look at the network tab in the browsers console, the request points correctly to "/CustomLogin/LocalLogin" with a HTTP Status Code of "302 - Found", but the "Location" header of the response is "/".
#196654
Sep 06, 2018 10:26
If you manually visit "/episerver" after being redirected to "/", is your user considered to be logged in?
Do you have an <authentication>-element in your web.config? If you have one, what does it look like?
#196659
Sep 06, 2018 12:43
Yes, after the user is redirected to "/" he can even see the orange EPiServer menu in the upper right corner and can access the backend.
That's what the <authentication>-element looks like in our web.config:
    <authentication mode="None">
    </authentication>
#196660
Sep 06, 2018 13:16
Does this happen in a specific environment?
Can you test what happens if you use the basic redirect code I posted above? You can first login (for example through "/Util/Login.aspx").
#196668
Sep 06, 2018 15:04
So far I have only tested this on my local machine (we have the DXC subscription).
Interestingly your code works. When clicking the "Test" button, I get redirected to /episerver/cms.
#196727
Sep 10, 2018 14:10
probably late to the party and not sure if it's related, but looking at `EPiServer.Cms.UI.AspNetIdentity.ApplicationUISignInManager<TUser>` you can see that it does redirect on its own.
public override bool SignIn(string providerName, string userName, string password)
  string returnUrl = this.GetReturnUrl();
  if (!this._signInManager().SignIn(userName, password, returnUrl))
    return false;
  this.Redirect(returnUrl);
  return true;
and there is custom redirect method in that manager:
protected virtual void Redirect(string returnUrl)
  HttpContext current = HttpContext.Current;
  if (current == null)
    return;
  if (string.IsNullOrWhiteSpace(returnUrl))
    return;
  try
    current.Response.Redirect(VirtualPathUtility.ToAbsolute(returnUrl), false);
    current.ApplicationInstance.CompleteRequest();
    current.Response.End();
  catch (ThreadAbortException ex)
NB! note `currect.Response.End()` method..
and redirect url is standard aspnet query string (if present) - "?ReturnUrl=..". you can give it a try and test login process with custom redirect url just to make sure that this signin manager is not messing things up.
#196756
Sep 11, 2018 7:35
I just tried to login with the ReturnUrl parameter like "/CustomLogin?ReturnUrl=%2Fepiserver%2Fcms" but again simply got redirected to "/" . undecided
#196764
Sep 11, 2018 10:04
it might be lost during post back to the controller maybe?
#196765
Sep 11, 2018 10:15
Is there a way to find this out?
#196812
Sep 12, 2018 9:53
can you add what request is being posted to the controller (can capture network traffic in dev tools for instance)?
#196947
Sep 18, 2018 9:25
LoginNetworkRequest
#196949
Sep 18, 2018 10:13
the login page is really a custom one (and just looks like built-in) or you use default epi login page?
#196952
Sep 18, 2018 10:47
Yes, this is actually a custom login page and just looks like the OOTB login page (for now ^^).
#196967
Sep 18, 2018 15:29
ok, and custom login page form containing action with "ReturnUrl" query string?
#196975
Sep 18, 2018 20:45
You can check the view here.
#196987
Edited, Sep 19, 2018 9:06
@using (Html.BeginForm("LocalLogin", "CustomLogin", new { ReturnUrl = "http://takemehome.com" }, FormMethod.Post))
#197026
Sep 19, 2018 15:25
Hello again Patrick!
I started setting up a project of my own which makes use of ASP.NET Identity. After I set it up I decided to take a proper look at solving this issue.
It was indeed the absence of ReturnUrl that caused it. The solution to this that I came up with can be found here:
https://world.episerver.com/blogs/jafet-valdez/dates/2018/9/curing-your-redirect-woes-when-using-uisigninmanager-signin/
The solution doesn't require you to set a ReturnUrl at all (if you don't want to) and it also enables you to use your OWIN configuration file to specify a redirect location when users sign in.
Hope this helps!
Thanks a lot @Valdis for pointing us in the right direction!
#197042
Edited, Sep 20, 2018 1:23
Thanks guys, with your help I was able to resolve the issue! cool
#197055
Sep 20, 2018 10:58
ah, nice. great success! I was lazy enough not to provide complete solution ;)
#197061
Sep 20, 2018 14:16
