Blocks with xhtmlstring not working after update
After an update to tinymce 2.6.1 no blocks with xhtmlstring works anymore. Geting: "Cant show blockname".
Any ideas what the problem is?
#196056
Edited, Aug 17, 2018 11:10
Are you using default TinyMCE configuration or you have custom settings?
#196077
Aug 17, 2018 14:07
The configuration is having the valuable part where will have the valuable for the user to update the operating system and where you will find XHTML string which was not working after the upgrade is done where you will need to provide the information which is needed then https://netgears.support/netgear-technical-support/ will help you to find the solution which is required for the user to understand the techniques and the query part.
#196546
Edited, Sep 03, 2018 21:11
