Redirect from one page to another page's section Episerver
Hi ,
I want to create functionality in which user can redirect from one page to another page's section.(eg. www.xyz.com/pagename#section1)
Here you can consider section as Block.
Could you please suggest any solution ?
Thanks in advance
#194565
Jun 25, 2018 15:38
Assuming you've implemented anchor functionality in your block... if you're using link property (public virtual Url MyProperty { get; set; }), editors should be able to set anchor inside Remaining Url field
#194568
Jun 25, 2018 16:38
Hi Dejan Caric,
Thanks but i m using Episerver 8.11.0.0 which has no such field name Remaining Url .
Could you please suggest any other solution ?
#194582
Jun 26, 2018 7:57
If you add the anchor a-tag in your block then you can/must use a link in for example TinyMCE since Epi has not implemented that functionality in that version
#194583
Jun 26, 2018 8:13
Hey,
I'd suggest using a block for that, you can find some inspiration here: http://mariajemaria.net/workaround-extending-linkitemcollection-support-anchors
Marija
#194917
Jul 08, 2018 16:01
If you can't upgrade I would say that Marija's answer is the correct one
#198250
Oct 24, 2018 7:59
