FallbackWithMaster vs Fallback LanguageLoaderOption
There are FallbackWithMaster & Fallback  LanguageLoaderOptions which DefaultContentLoader uses to load a content. FallbackWithMaster loads content like Fallback, additionally in case of no available fallback language it loads from the Master language. So, FallbackWithMaster looks like a better option to use always. Any information around use cases, which option to use when?
#190333
Apr 09, 2018 16:12
Ira,
I assume you're using CMS 10 or higher? Have you had a chance to read this article?: https://world.episerver.com/documentation/developer-guides/CMS/Content/icontentrepositorydatafactory-interface1/
#190334
Apr 09, 2018 17:07
Hi Bob,
Yes, I'm using Episerver 10, I am aware of the information present in the article, however it doesn't answer my question. I wanted to know when would a user want to use Fallback option instead of FallBackWithMaster. https://world.episerver.com/documentation/Class-library/?documentId=cms/10/CA41A7DE. When clearly FallBackWithMaster is nothing but a Fallback with additional fallback to master.
#190341
Apr 09, 2018 18:47
Hi Ira,
I think you would use the FallBackWithMaster when you always want to return content (browsing in language A but content doesn't exist in that language but it doesn't either exist in the configured fallback language so fallback to master).
You would use the FallBack when you want to fallback to configured language and if content doesn't exist in that fallback return not found (browsing in language A but content doesn't exist in the language so fallback to configured language B, content doesn't exist in language B so content was not found).
So the difference is: do you always want to return content or do you want to return not found in some cases.
#190345
Edited, Apr 09, 2018 20:38
Hi Antti,
Thank you for the clarification. Yes, seems so, different load options are available and which one to use depends on the project and specific requirements.
#190356
Apr 10, 2018 9:55
