Redirect all URLs so they end with /
Ayo
Ayo
Is there a way to configure episerver so that all my URLs end with slash.
So for example if a user navigates to www.mywebsite.com/en/home they are redirected to www.mywebsite.com/en/home/
Thanks in advance.
Ayo
#189373
Mar 16, 2018 14:58
This can be done with URL Rewrite
<rule name="Add trailing slash" stopProcessing="true">
  <match url="(.*[^/])$" />
  <conditions>
    <add input="{REQUEST_FILENAME}" matchType="IsFile" negate="true" />
    <add input="{REQUEST_FILENAME}" matchType="IsDirectory" negate="true" />
  </conditions>
  <action type="Redirect" redirectType="Permanent" url="{R:1}/" />
</rule>
#189376
Mar 16, 2018 15:33
Ayo
I did it by adding this to my global asax.cs file:
protected void Application_BeginRequest(Object sender, EventArgs e)
if (HttpContext.Current.Request.Url.AbsolutePath != "/" && !HttpContext.Current.Request.Url.AbsolutePath.EndsWith("/"))
string redirect = HttpContext.Current.Request.Url.AbsolutePath;
redirect = redirect + "/";
Response.Clear();
Response.Status = "301 Moved Permanently";
Response.AddHeader("Location", redirect);
Response.End();
UPDATE: Doing it via the webconfig is better so we don't redirect .css URLs or .jpg URLs.
#189377
Edited, Mar 16, 2018 15:51
Ayo
thanks for your reply Quan Mai
Used your method and it works great on the front end, but the issue is it breaks the episerver back end, how can I exclude all URLs assosiated with the back office?
#189387
Mar 16, 2018 18:35
You should be able to do that by adding this rule before the previous rule, assuming /episerver is your admin path
<rule name="block" stopProcessing="true">
    <match url="^/episerver$" ignoreCase="true" />
<action type="None" />
</rule>
#189388
Mar 16, 2018 19:04
Ayo
I did try that but its still breaking the back office.... I posted a simlar question on stack overflow... I'll copy and paste it......
I want to create a URL rewite rule that adds a / on URLs that don't have one so for example:
www.domain.com/news/latest will get redirected to www.domain.com/news/latest/
The rule below does exactly that, but the problem I am having is two fold:
  1. This rewrite rule is getting applied to things like image files. So For example domain.com/globalassets/icons/image.svg gets changed to domain.com/globalassets/icons/image.svg/ causing a 404 its not happening with CSS files which is strange, maybe because I am adding them using the RegisterBundles method in MVC?
  2. This is a ASP.net MVC based website using a CMS (episerver) so I want to ignore any redirects in the Admin area so I added a second rule, but again its doing this to the CSS and images breaking the admin area.
This is what I have got so far, can anyone help me get this rule working correctly?
I just want this to work for the URL's to pages only and not effect the other supporting files like images and css, js files.
#189561
Mar 20, 2018 16:23
What do your entire UrlRewrite rules look like?
#189563
Mar 20, 2018 16:24
Ayo
At the moment it looks like this....
<rewrite>
<rules>
<rule name="Exclude Slash Episerver " stopProcessing="true">
<match url="^episerver/" />
</rule>
<conditions>
</conditions>
</rule>
</rules>
</rewrite>
[Pasting files is not allowed][Pasting files is not allowed][Pasting files is not allowed]
#189565
Edited, Mar 20, 2018 16:46
I dont' think this is correct, did you try with ^/episerver$ instead?
<match url="^episervers/" />
#189566
Mar 20, 2018 16:49
Ayo
Yeah I did try that first (going to try it again now) but it didn't work... is $ a wild card? so it catches anything with  /episerver/matchesAnyThingAfterTheSlash  ?
#189567
Mar 20, 2018 16:52
Hmm. $ is the end of the regex. This works for me on Quicksilver
<rule name="add trailing slash" stopProcessing="true">
<match url="(.*[^/])$" ignoreCase="true"/>
<conditions>
<add input="{URL}" pattern="^/(Login|episerver|util)" negate="true"/>
</conditions>
</rule>
So it's a bit different way, but same purpose. Login is optional, while episerver|util is required
#189572
Mar 20, 2018 17:34
I think the addition of the "util" part of the pattern is the key piece there Quan :)
#189573
Mar 20, 2018 18:10
For future visitors, I wrote a blog post explaining the "magic" https://vimvq1987.com/adding-backslash-ending-to-your-urls-by-urlrewrite/
#189598
Mar 21, 2018 9:55
Ayo
That works! - Thank you.
#189604
Mar 21, 2018 10:44
Ayo
One more thing.... I just put this on to my staging server and we have a SSL certificate, now I am getting errors about mixed content, becuase some JS and CSS is now coming over http.... if I remove the rule it goes away....
Is there something I need to do to account for the fact I am using a SSL certificate.
#189608
Mar 21, 2018 12:44
There is a singelton instance of EPiServer.Web.Routing.RoutingOptions registered in IOC container. You can set the property UseTrailingSlash on the options class to control if you want the generated URL:s to have an trailing slash or not.
#189708
Mar 23, 2018 8:49
Ayo
Hi Johan,
This looks like exactly what I need, I had no idea episerver had something like this built in out of the box.
BUT.... I can't get it to work. This is what I have got...I have added this to my app start method, but I am not getting the / at the end of the URLs, do I need an IIS redirect as well?
I Put a break point in this method and I can see that routingOptions.UseTrailingSlash is already set to true, but my Urls are a not being redirected to have the / on the end...
protected void Application_Start()
      AreaRegistration.RegisterAllAreas();
      BundleConfig.RegisterBundles(BundleTable.Bundles);
      AutoMapperConfig.InitializeMappings();
      var routingOptions =
      ServiceLocator.Current.GetInstance<RoutingOptions>();
      routingOptions.UseTrailingSlash = true;
any ideas.... any one?
#189722
Mar 23, 2018 11:13
I was probably a bit unclear, setting UseTrailingSlash will not do any redirection it will only assure that generated urls contain a trailing slash (then hopefully there will not be that common there will be request wwithout a trailing slash)
#189723
Mar 23, 2018 11:16
Also the recommended way to set options is to use Configure method in a IConfigurableModule like:
            context.Services.Configure<RoutingOptions>(o => o.UseTrailingSlash = true);
#189724
Mar 23, 2018 11:27
Ayo
OK, so the only way to do it so there is a redirection is by a URL re-write?
The issue I am having is with SSL...
When I use the rule below, it works on my Local Machine....but when I put it on the staging server I get this error,
Mixed Content: The page at 'https://www.bit.truphone.com/uk/iot-solutions/' was loaded over HTTPS, but requested an insecure stylesheet
and the CSS gets blocked.
<rules>
<conditions>
<add input="{URL}" pattern="^/(Login|episerver|util|App_Themes)" negate="true"/>
</conditions>
</rule>
#189729
Mar 23, 2018 11:43
If you prefer then you can do the redirection in code instead of in config, like below that attaches an eventhandler to IContentRouteEvents in a IInitializableModule:
            context.Locate.Advanced.GetInstance<IContentRouteEvents>().RoutedContent += (s, args) =>
                var currentPath = args.RoutingSegmentContext.RequestUrl.AbsolutePath;
                if (!currentPath.EndsWith("/") && string.IsNullOrEmpty(VirtualPathUtility.GetExtension(currentPath)))
                    args.RoutingSegmentContext.PermanentRedirect(VirtualPathUtility.AppendTrailingSlash(args.RoutingSegmentContext.RequestUrl.ToString()));
#189730
Mar 23, 2018 11:58
Ayo
I tried to do in code before with this...
Response.Clear();
Response.End();
but the problem I have is everything over http gets this redirect so image URLS /path/path/image.jpg gets redirected to /path/path/image.jpg/ and that gets a 404
This is starting to drive me nuts... there must be a way! :-)
#189731
Mar 23, 2018 12:08
Ayo
@ Johan Björnfot
Thank you, thank you thank you.
Doing it in code works, I had a look at your code and I get it now.... this URL redirect only applies to Routed Content that comes from episerver. THANK YOU... works in the staging server too with no SSL problems!
THANK YOU!
#189740
Mar 23, 2018 12:51
Ayo
Just in case someone else finds this post, here is a quick update. I had to modify the code from Johan, to exclude the back office episerver paths, if you don't do this it will break things like thumbnail previews:
var currentPath = args.RoutingSegmentContext.RequestUrl.AbsolutePath.ToLower();
if (!currentPath.EndsWith("/") && !currentPath.Contains("episerver") && !currentPath.Contains("util") && !currentPath.Contains("App_Themes") && string.IsNullOrEmpty(VirtualPathUtility.GetExtension(currentPath)))
#189757
Edited, Mar 23, 2018 15:57
there are lot more things to be aware of that don't need trailign slahes :) like signalr hubs is one of the first that came to my mind.
#189814
Mar 24, 2018 20:39
Ayo
Hi guys, in the end this is the code that works! it's doing the redicrect on all URLs that don't have the / apart from any paths that are related to Episerver
    [InitializableModule]
    public class TrailingSlash : IInitializableModule
                if (!currentPath.EndsWith("/") && !currentPath.Contains("episerver") && !currentPath.Contains("util") && !currentPath.EndsWith("App_Themes") && string.IsNullOrEmpty(VirtualPathUtility.GetExtension(currentPath)))
BUT..... when redirection happens this is what it does
A. https://www.mywebsite.com/uk/products (301)
B. http://www.mywebsite.com/uk/products/ (301)
C. https://www.myserbsite.com/uk/products/ (200)
Is there a way to make it just go from A to C without going to B?
#192205
May 10, 2018 15:35
which protocol is set as default for your site?
#192206
May 10, 2018 15:42
Ayo
https on the live site, but on my developer machine.... I just use http
#192207
May 10, 2018 15:44
why would you have different settings than production? you have to switch to ssl (even locally) and force it via IIS / episerver site bindings.
#192208
Edited, May 10, 2018 15:45
