Property List - Show/Hide Property for CMS editors based on other Property value
Background:
I need to implement the ability for CMS editors to associate a list of facets to a page type.
They need to be able to select the facets from a pre-defined list, reorder the facets and add ranges for range facets.
I'm using Episerver CMS 10.10.4.
Issue:
I'm trying to use property lists to define the facets and the facet ranges, so I don't implement a custom property from scratch. However, I couldn't find a solution that works with property lists for hiding the ranges when adding/editing non-range facets.
e.g.
I've tried adding a block to contain the property list or the property list item, but that breaks out the display for the property list.
References:
https://world.episerver.com/Blogs/Duong-Nguyen/Dates/2014/1/Country-Region-drop-down-lists-in-All-properties-mode/
https://developerschallenges.com/2017/11/02/episerver-all-properties-component-for-showing-and-hiding-content-using-a-drop-down/
Does anyone have an idea on how I can achieve this?
Code:
public class ProductListingPage : SitePage
        [Display(
            Name = "Custom Facets to display on page")]
        public virtual IList CustomFacetsList { get; set; }
[PropertyDefinitionTypePlugIn]
public class CustomFilterProperty: PropertyListBase
	[SelectOne(SelectionFactoryType = typeof(FacetDefinitionSelectionFactory))]
	[Required]
	public string Filter { get; set; }
	[EditorDescriptor(EditorDescriptorType = typeof(CollectionEditorDescriptor))]
	public IList Ranges { get; set; }
public class RangeFilterProperty: PropertyListBase
	public int? From { get; set; }
	public int? To { get; set; }
[EditorDescriptorRegistration(TargetType = typeof(IList))]
public class CustomFilterCollectionEditorDescriptor: CollectionEditorDescriptor
	public override void ModifyMetadata(ExtendedMetadata metadata, IEnumerable attributes)
		ClientEditingClass = "app/editors/CustomFilterCollection";
CustomFilterCollection.js
define([
    "dojo/_base/array",
    "dojo/_base/declare",
    "dojo/_base/lang",
    "epi-cms/contentediting/editors/CollectionEditor"
function (
    array,
    declare,
    lang,
    CollectionEditor
    return declare([CollectionEditor], {
        _getGridDefinition: function () {
            var result = this.inherited(arguments);
            result.ranges.formatter = function (values) {
                return values != null ? values.map(msc => msc.from + " - " + msc.to).join("
") : ""; }; return result; } }); });
#189437
Edited, Mar 19, 2018 14:29
